**taerae86 goes supercharged!**
Old Mar 4, 2012 | 03:07 PM
  #126
taerae86's Avatar
awesome, thanks!
Old Mar 4, 2012 | 03:14 PM
  #127
heathkidder's Avatar
Are u runnin one h.e
Old Mar 4, 2012 | 03:55 PM
  #128
taerae86's Avatar
yesssir
Old Mar 4, 2012 | 04:07 PM
  #129
Pmd
Old Mar 4, 2012 | 07:11 PM
  #130
taerae86's Avatar
thanks again for the info heath!
here's some pics from the weekend...
intake mani is fixed!
friday - got the front bumper off...
...and my dog got jealous that he wasnt getting his pic taken lol
saturday - got the intake mani, IC pump, spark plugs, injectors, idler assembly, etc, in...
sunday (today) - made some new brackets for the heat exchanger, got that on and got the hoses ran...thanks to my dad & bf on that one lol
so things are moving along! still wondering about the whole MAF/MAP wiring deal though so if anyone has any information on that, that would greatly help!
Old Mar 4, 2012 | 07:13 PM
  #131
royce777's Avatar
looks good!
Old Mar 4, 2012 | 07:20 PM
  #132
Did u put intake mani bracket on
Old Mar 4, 2012 | 07:31 PM
  #133
conerboner's Avatar
i kind of want to get a sedan base model and supercharge it lol
Old Mar 4, 2012 | 09:03 PM
  #134
taerae86's Avatar
Originally Posted by royce777
looks good!
thanks!
yeahh, what a bitch lol
Old Mar 4, 2012 | 10:03 PM
  #135
Bracket was easy lol are u an auto?
Old Mar 4, 2012 | 10:52 PM
  #136
bluebalt07's Avatar
^Mine wasn't lol I had to drill out the holes some and tap them
Old Mar 4, 2012 | 10:54 PM
  #137
really? mine went right in lol
Old Mar 4, 2012 | 11:03 PM
  #138
IonNinja's Avatar
what HE is that?
Old Mar 4, 2012 | 11:34 PM
  #139
Axelthered05's Avatar
I will just leave this here
Old Mar 5, 2012 | 08:43 AM
  #140
taerae86's Avatar
no, manual...the bracket was easy to get on, for me, it was getting the bolt through the mani to the bracket that was a bitch becuase by that point, i already had my alternator and such back in place so it was just a tight space to get at lol
Originally Posted by IonNinja
what HE is that?
uhm, i believe it's the CA one from way back when...
Originally Posted by Axelthered05
thanks, but i have that diagram lol if you go back to the page before this, my stock MAP has two tan wires, so i'm wondering which one is supposed to be used in the new MAP...AND if they're all spliced together, not omitting anything but the stock MAP? OR if you like take from the stock MAF to the new MAP and omit that wire from the stock MAF. (IE - the stock MAP connector is no longer needed, but what about the wires from the stock MAF? do they get spliced into with the wire from the new MAP?)
i guess i know (i think) that the stock MAP connector will be completely cut off and those wires soldered to the new MAP, correct? so then the wires from the stock MAF, are they spliced into the new MAP or cut completely off and omitted from the stock MAF to put onto the new MAP? and which tan wire from the stock MAF is the correct one to use? lol i cant really find anything that gives detail about wiring that except for that diagram, but i'm not trying to cut up anything until i'm 100 percent positive on what i'm doing lol.
Old Mar 5, 2012 | 10:09 AM
  #141
Doomstar's Avatar
You are using the 2.5 LSJ MAP?
Old Mar 5, 2012 | 10:17 AM
  #142
oh my bad the outside tan wire is the signal for the IAT the tan wire next to the center pin is the Low referance. this is what you do, you cut the IAT wires from the MAF sensor conector MAKE SURE YOU LABEL THEM BEFORE YOU CUT then conect them to the conector for the new MAP sensor. The IAT sensor built into the MAF snesor is unused and sould not be left un conected. You then cut the wires from the OLD MAP sensor conector and conect them to the new MAP conector
just FYI the pinout of all cobalt MAF sensors are the same the 2.2 just uses diferent color wires
Old Mar 5, 2012 | 10:30 AM
  #143
taerae86's Avatar
correct...
http://i1061.photobucket.com/albums/...esCAD91HI8.jpg
got ya...this was VERY helpful! thank you so much!
this part makes me confused though? lol
Old Mar 5, 2012 | 07:31 PM
  #144
taerae86's Avatar
Ebay has 6 pin to 8 pin pigtail around 50 bucks
Is this what you got? Ebay - LSJ 8-Pin Throttle Body to 6-Pin LE5 or L61 Harness Adapter
Old Mar 5, 2012 | 11:39 PM
  #145
sorry I edited that and left it in there, it should read "the IAT built into the MAF sensor should be left unconected"
Old Mar 5, 2012 | 11:43 PM
  #146
c1_c1rca's Avatar
builds looking good!
Old Mar 6, 2012 | 01:24 AM
  #147
Thats the right one
Old Mar 6, 2012 | 08:16 AM
  #148
taerae86's Avatar
it's all good...i read it like five times and was talking about it with my dad, i'm like thats confusing it seems as though it should be left unconnected lol thanks again for the help!!
thank you!
Thats the right one
thanks ordered it...
Old Mar 6, 2012 | 09:35 AM
  #149
zerosk8ter83's Avatar
lookin good
Old Mar 6, 2012 | 09:44 AM
  #150
taerae86's Avatar
thanks
