06 LS bogging / speedo issue
Old Sep 22, 2010 | 02:25 PM
Mr.N00bLaR's Avatar
Sometimes when I'm coming to a stop (10-0mph) my speedo will not reflect my actual speed. The needle dances through the speeds up to 60-70 mph while I'm sitting still.
Example:
0920001537.mp4 video by nanoman06 - Photobucket
After this has happened and when the light turns green or its my turn to go through the intersection the car feels like it is bogging (staying under 2k rpms longer than I'd expect), not as responsive as I would expect for a few seconds. After this happens sometimes the car jerks forwards (even if I'm not flooring it and I don't make a whole lotta power :sadface)
Seems to happen on both cold and warm starts. I can't figure out how to replicate the issue but if you drive the car in a stop-and-go setting like a town you will definitely experience this soon or later.
I have noticed one other thing on the way home with my cruise control on. For most of the miles home with it on it was functioning normally. I think it happened once, where on a flat strip of road, no bumps nothing to slow me down I noticed the car rev'd by itself to 3.1k. For the speed I was going I only need about 2.5. Seems like while the car was on CC it slowed down or the CC stopped working for a few seconds then kicked back in. This seemed strange to me so I figured I'd add this in.
I have no malfunction / check engine lights on. I used seafoam and cleaned the TB about two months ago (4,000) miles ago. I'm at 582xx miles now. Anybody run into this? Over the weekend I might try new plugs and fuel filter but would those also be the cause of the speedo acting weird?
Old Sep 23, 2010 | 10:37 AM
ShadowStal3er's Avatar
oh chevy and your notorious speedo issues... this is an issue with so many gm cars... the clusters just stop working... i never did find out why... the tach in my moms suburban says she is at -250 rpms at idle.... i guess her engine turns backwards till she gets moving lol... but if you google chevy og gm speedometer issues you will find this all over the place.
Old Sep 23, 2010 | 04:54 PM
Mr.N00bLaR's Avatar
Definately possible, do you think that could be the issue behind the bogging as well?
Old Sep 23, 2010 | 10:40 PM
not so much... clean your tb and all your intake parts.
Old Sep 23, 2010 | 11:33 PM
I'm going to assume you're an auto trans, check all your fluids, and sensors, then have someone who can pull error codes check it out.
Old Sep 23, 2010 | 11:50 PM
time to flush your ENTIRE CAR... get a fuel system cleaning service done
Old Sep 24, 2010 | 12:00 AM
Mr.N00bLaR's Avatar
I'm a human being dammit! I have an auto trans in my car yes
I don't see any CEL on but is it possible for there to be error codes without that on? Ill try to check in with a neighbor, he might have access to a tech II.
Old Sep 24, 2010 | 12:09 AM
Does your cel light up when you start your car? (damn light bulb is out you wont be able to see it, fussy things)
Old Sep 24, 2010 | 05:53 PM
Mr.N00bLaR's Avatar
It lights up with the other lights like it is supposed to when the car starts up and turns off after that period like the rest of them so, I would assume it's working correctly and I don't have any codes.
Old Sep 24, 2010 | 06:26 PM
Then i'd check fluids, maf sensor, coilovers and plugs. somewhat random when was the last time you cleaned your air filter?
Old Sep 25, 2010 | 01:10 AM
just realized i typed coilovers, not coil packs...
Old Sep 25, 2010 | 01:34 AM
lol I knew what you meant lol
Old Oct 27, 2010 | 10:11 AM
averagewhiteboy's Avatar
Yeah dude, that's harsh. I'm having issues, as we discussed, but not that phantom speedo.. But I did replace my 2.4 white-faced one with a black SS s/c 160 one..
Old Oct 27, 2010 | 11:24 PM
joshc.'s Avatar
The bogging issue could be a TPS sensor I saw something similar happen on a L61 Malibu. The TPS voltage would suddenly fluctuate causing the RPM to jump during cruise then when hot the TPS would be very slow to react causing a bog.
Old Oct 27, 2010 | 11:31 PM
Mr.N00bLaR's Avatar
Hmm, interesting. It's at the dealer now. Hopefully its nothing expensive...lol.
BTW, are you the guy who used to run ef?
Old Oct 28, 2010 | 12:21 AM
joshc.'s Avatar
Sorry can't say I am. I am on there but never ran it, That would be NJHK.
Old Oct 28, 2010 | 08:44 AM
Nooblar, for whatever it's worth, I super duper cleaned my TB and my MAF yesterday and it seemed to help alot with my poor reaction.. I'd check it out. But definitely keep us updated.
Old Oct 30, 2010 | 07:47 PM
Mr.N00bLaR's Avatar
Got the car back! The wiring to the speed sensor needed to be replaced.
Old Oct 30, 2010 | 07:48 PM
So that fixed the random speedo action? How about the bogging and such?
Old Oct 30, 2010 | 07:59 PM
Mr.N00bLaR's Avatar
It fixed all of the issues I had actually. I thoroughly tested it today...haha. I got the PS recall done to (even though I didn't think I needed it) and it seems easier to steer now, guess I did need it.
Old Oct 30, 2010 | 08:00 PM
Hmm, so what exactly did they replace/do?
Old Oct 30, 2010 | 08:07 PM
Mr.N00bLaR's Avatar
"Vehicle speed sensor harness is shorting to ground R&R harness replace 6-10 inches of harness and reroute to clear engine."
Old Oct 31, 2010 | 12:06 PM
haha Gotta love tech's explanations..
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
