07blackg5 Build Thread. Operation Moneypit
Old 03-01-2015, 10:17 PM
  #276
ssyellow's Avatar
Lord jesus lets make her run 9s.
Old 03-02-2015, 06:03 AM
  #277
Slobodan Milošević
07blackg5's Avatar
For that 10 seconds or less, I'm free
Old 03-03-2015, 12:12 PM
  #278
Slobodan Milošević
07blackg5's Avatar
I placed an order for a **** ton of the bolts I needed. I also got an assortment of shoulder bolts to test with. I will keep you guys posted when they show up.
Boltdepot.com is the **** if no one's used it before
Old 03-03-2015, 12:48 PM
  #279
Slobodan Milošević
07blackg5's Avatar
Got a bunch of stuff in the mail yesterday too.
-braided clutch line
-TOB
-map pigtail
-new 2.5 bar map
-some misc AN fittings
-a tensioner bolt from CED
Im pretty stocked up on stuff at this point haha
Old 03-03-2015, 10:15 PM
  #280
Slobodan Milošević
07blackg5's Avatar
pulled the rear o2 sensor leads out of the harness. I think this is as stripped as it can get without doing anything too crazy. I also split off the throttle body leads from the other branch it was loomed with, but it was after this picture.
The only thing I dont like is that the injector harness originally wrapped around the bottom of the intake manifold and came across the fuel rail from the passenger side. I might re-wire/shorten it so that it approaches the rail from the drivers side. it is the only thing left on the "branch", and it seems silly to have it make a big ass loop when nothing else is run that way. I just want to cut as little as possible, but I know I wont be happy if I dont
Old 03-03-2015, 10:48 PM
  #281
Spawne32's Avatar
How's the condition of the wires in the harness, especially at the bends. I just had to order an entire rear ABS harness for my car because of damage from who knows what. I knew it had been torn up and the copper was exposed on one of the wires but never threw a code for it. When I installed my 245 tires up front today, soon as I got on the highway it threw a code for that specific sensor with the damage, guess the discrepancy between the front and back was more noticeable on the damaged harness side. Anywho, was gonna cut and splice but I figured let me see if i can just fine a harness section, wound up finding this.
Amazon.com: ACDelco 10365534 GM Original Equipment Electronic Brake Control Wiring Harness: Automotive Amazon.com: ACDelco 10365534 GM Original Equipment Electronic Brake Control Wiring Harness: Automotive
Im curious if im going to find similar wear and tear on the engine bay harness, the loom was completely destroyed on the coil side when I bought my car, and I had rewrapped it with heat resistant nylon sleeve.
Old 03-03-2015, 10:55 PM
  #282
Slobodan Milošević
07blackg5's Avatar
Everything looks fine to me. I didnt go over it super fine, but there was no obvious damage or major kinks that would be potential issues.
And ive been poking around the factory tune you sent me. I'm pretty overwhelmed, but i'm getting the hang of navigating around. Is this 100% factory? it looks like the rev limiter is 7000rpm, unless im looking at the wrong thing.
Old 03-03-2015, 10:58 PM
  #283
Spawne32's Avatar
I think you are looking at my file instead of the 2.2 tune lol im looking at 6500rpm on the tune i sent you for the 2.2, it was pulled right off hptuners repository. It's the one with all the numbers.
Old 03-03-2015, 11:05 PM
  #284
Slobodan Milošević
07blackg5's Avatar
well ****. lmao
Old 03-03-2015, 11:12 PM
  #285
Jesse's Avatar
And you aren't even automatic. That opens a whole nother can of worms. Helps to learn to tune NA first so it isn't so intimidating going SC.
Old 03-03-2015, 11:15 PM
  #286
Slobodan Milošević
07blackg5's Avatar
I just want to be familiar enough with the software to make minor adjustments if needed. Not have to bug anyone to make simple changes.
Long term I would like to work up to being well versed in the arts, but for now I just want to not be totally ignorant of whats going on
Old 03-03-2015, 11:21 PM
  #287
Spawne32's Avatar
stay away from the trans stuff when you look at my tune, look at airflow, fueling, spark, etc
Old 03-03-2015, 11:28 PM
  #288
Slobodan Milošević
07blackg5's Avatar
Where is the dump fuel like a waterfall button?
I havent looked at your tune yet, just the 2.2 one. I was looking at the wrong thing. it looks like the stock limiter is 6600, but im probably still looking at the wrong thing haha.
I think my mercedes bosch pump shows up tomorrow. really the only thing left I need is the clutch and flywheel, and wire loom for the harness. Of course there will be odds and ends here and there that will nickel and dime me to death, but for the most part I think I have everything down to the bolt
Old 03-03-2015, 11:30 PM
  #289
Slobodan Milošević
07blackg5's Avatar
derp. and an intake
Old 03-03-2015, 11:34 PM
  #290
Spawne32's Avatar
lol this is just to change the rev limit
Old 03-03-2015, 11:46 PM
  #291
Slobodan Milošević
07blackg5's Avatar
sensory overload haha. I wish I would have messed with this before I blew my car up, but I didnt get hpt until I did.
I dicked around with the nitrous setup with the intention of testing the limits and how different things reacted, without worrying about blowing the car up. I wish I would have gotten hpt sooner and tried to work a tune out. I would have been able to experiment and learn without having to worry. Oh well
Old 03-03-2015, 11:48 PM
  #292
sandman's Avatar
I'm really considering picking it up and learning it haha. I've watched while my car was being tuned
Old 03-04-2015, 12:01 AM
  #293
Spawne32's Avatar
Best advice I can give you is dont put too many variables in the equation at once, that means, dont start with a heavily modified engine that needs a fresh tune, and throw E85 and nitrous at it all at once. Tune it gradually. Get the car broken in and tuned on E85 properly before you start blasting it with nitrous. You wanna be sure the car is tuned well and ready for that NOS before you start spraying horsepower into your motor.
Old 03-04-2015, 12:16 AM
  #294
Slobodan Milošević
07blackg5's Avatar
That's definitely the plan. I didn't plan on running the spray for quite a while.
I just meant I wish I had experimented with tuning like I had experimented with the nitrous. Get a feel for everything before I started anything major
Old 03-04-2015, 12:56 AM
  #295
ThexGovenor's Avatar
Start with timing really low so you can dial in your Airflow. It will be hard with the scaled tune/no good base to go off of. Once airflow is dialed in bring up the timing gradually!
Old 03-04-2015, 01:52 AM
  #296
Jesse's Avatar
One piece of advice for anyone who tunes E37/67 leave the adaptive idle spark tables alone. Otherwise you get surging at idle in park and 2500rpm startups.
Old 03-04-2015, 05:47 PM
  #297
Slobodan Milošević
07blackg5's Avatar
I got the bigger bosch pump today. I wanted to see if i could fit my 3/4 hose over the in/out, and it was a tight fit.
People had mentioned using a reducer to take the 7/8 back down to a 3/4, but I wanted to see if that could be avoided (less joints to potentially leak).
My 3/4 hose started over the outlet, but wouldnt slide down dry. not easily at least. I'm sure it can be done, but if you use a tiny bit of lubricant, i'm sure it would go on easily.
Old 03-04-2015, 06:56 PM
  #298
toolman's Avatar
Lubricant always helps when you try pushing something into a tight hole. It also helps to work it in there slowly; going to fast may cause the tube to tear open on the side.
Old 03-04-2015, 07:02 PM
  #299
Slobodan Milošević
07blackg5's Avatar
-_-
Old 03-04-2015, 09:24 PM
  #300
Spawne32's Avatar
Quick Reply: 07blackg5 Build Thread. Operation Moneypit
