07blackg5 Build Thread. Operation Moneypit
#301
So i experimented with tapping the cylinder head for M8 today, went pretty much flawlessly, except for the fact that I tapped the cylinder head to the wrong ****** size for M8, as I was reading my crossreference chart for the taps wrong. -_- So now im waiting on a keylock threaded insert kit and tools to come so I can fix the holes and test fit the manifold and spacer on my spare head.
#303
#316
har har har lol my threaded inserts showed up today as well so I can get back to work on this. Wasnt able to get to home depot today with the snow, wound up spinning the balt out and doing a 180 into oncoming traffic and slid up into a curb trying to drive my friend home, called it quits after that.
#317
#319
so it turns out the SS radiator is significantly thicker than the base radiator. I was always under the impression that they were the same, but they are not. I even looked up the GM part numbers and they are different, the ss being ~25 more expensive
#320
Is it going to cause any problems? Are you going to use the dual fan setup from an SS too?
#321
Im going to use the single fan. I have the zzp radiator, so I'm not worried about it for myself.
I sent my old radiator to a fellow member with an ss whose radiator was leaking. All the mounting is the same, just the thickness is different. Should only make a mild difference, if any at all.
#322
I might have pulled a spawn -____- lmao
I cut out the alternator leads from the harness because I planned to use my aftermarket alternator with no plugs. Well I just sent an email to the company seeing about swapping it for a 6 rib....
I havent heard back but I checked the site and they dont have an option for the supercharged modes. I'm hoping they can help me out.
The oem alternator needs the harness to "excite" or turn on the voltage regulator, where my aftermarket is self sensing. Whoopsie. Now i'm just watching my email for hopefully good news haha
#325
If I were you I would just try to grab a ss/sc downpipe for cheap. the 07-08 l61 manifolds are nicer than the pre 07. If you plan to go s/c in the future you could get a shorty and 2.5" downpipe, or the midlength, but if you are planning on staying n/a, just find a downpipe.
The power differences will be minimal, but the price difference is a lot
