07blackg5 Build Thread. Operation Moneypit
Old 02-20-2015, 04:52 PM
  #101
Slobodan Milošević
07blackg5's Avatar
Hoping to at least get the bottom end to a machine shop before the end of the month. Maybe the first week of march.
Still so much to do
Old 02-20-2015, 05:42 PM
  #102
Spawne32's Avatar
mmm i love me some shiny new car parts thats a hell of a heat exchanger you have there, griffon im assuming?
Old 02-20-2015, 05:59 PM
  #103
Slobodan Milošević
07blackg5's Avatar
Zzp stealth. Got it for 200 bucks on black friday
Old 02-20-2015, 06:01 PM
  #104
Spawne32's Avatar
Oh awesome, i was ranting and raving on their FB when i got my catback for 280 something shipped down from almost 500. lol
Old 02-20-2015, 06:16 PM
  #105
Slobodan Milošević
07blackg5's Avatar
I love my zzp catback. Sounded perfect with my ottp longtube. I'm surprised they stayed joined this long. I figured the bolts would have snapped from the opposing pressure...
Old 02-20-2015, 09:33 PM
  #106
sandman's Avatar
Originally Posted by supernovanator
Hmmm maybe it's just a matter of wiring. Oh well. The 07+ use E37 and the 2.4 2007 and prior all use E67. 2008+ use the same E37. They are practically the same. I'm just confused I guess. Maybe it's the map sensor that won't read more than a certain amount.
But the engine itself is pretty much all the same that they can be interchanged right? Just a new computer?
Old 02-20-2015, 09:35 PM
  #107
Slobodan Milošević
07blackg5's Avatar
The engines are different, the computer is the same. The 2.4 just needs the 2 vvt solenoids wired in and a sensor.
Old 02-20-2015, 09:37 PM
  #108
Slobodan Milošević
07blackg5's Avatar
Or are you talking pretty 07 l61 vs 07 08 l61? Heads are different and different crank ring, and the different computer
Old 02-20-2015, 09:44 PM
  #109
Jesse's Avatar
I think he's talking about 07LE5 vs 08LE5.
If you mean between the 07 vs 08 LE5 yeah they should be the same. Just no forged internals on the 2008+ engine, and 08+ has the E37 vs the earlier E67. However, tuning the two is almost identical also. E37 has VVT tables.
Old 02-20-2015, 09:52 PM
  #110
Slobodan Milošević
07blackg5's Avatar
lol the one combo i didnt consider. 08 has a different intake manifold too
Old 02-21-2015, 01:06 AM
  #111
sandman's Avatar
I'm definitely gonna throw a LE5 in my car lol
Old 02-21-2015, 02:04 AM
  #112
Spawne32's Avatar
You dont know the power of the dark side of the force, muhahaha.
Old 02-21-2015, 02:29 AM
  #113
sandman's Avatar
I will soon hahaha
Old 02-21-2015, 08:52 AM
  #114
Slobodan Milošević
07blackg5's Avatar
Everyone is going to the dark side, and I'm just over here hacksawing everything
Old 02-21-2015, 12:14 PM
  #115
Spawne32's Avatar
lol your doin a good job, trust me id be complaining and getting infractions if i didnt like something here. I wasnt nearly as meticulous when I rebuilt my LE5 last year, i was tired, fresh out of surgery, fed up with the problems i was having with it and just wanted the car back. I honed the block with my flex hone, sanded the deck with a flat block of glass and 600 grit to clean it off and get a decent finish for the head gasket, and measured the bearings and rings and reassembled everything after washing the block out thoroughly. I spent 3 weeks waiting for a tap and drill bit for the absolutely retarded thread size of the piston oil squirters which stripped out and had to be drilled out.
Old 02-21-2015, 12:52 PM
  #116
Slobodan Milošević
07blackg5's Avatar
2.2s don't have oil squirters. I debated buying a zzp girdled block, but that's a grand I would rather not spend.
It's a Gen 2 block and lnfs push them past 450hp. I hope to be around 400 all the time, with an occasional 35 shot
Old 02-21-2015, 12:56 PM
  #117
Slobodan Milošević
07blackg5's Avatar
Blower 400 is like turbo 450+ in terms of stress, but everything is getting balanced, so that should take a bit of unnecessary stress off everything. I will still be at the limits of the block, but it should be okay
Old 02-23-2015, 04:36 PM
  #118
Slobodan Milošević
07blackg5's Avatar
Block and parts are going to the machine shop this sat.
Does anyone think I should go for an lsj oil pan for the extra capacity? I know the standard one will be fine, but any additional capacity helps. Any reason not to go to an lsj pan?
Old 02-23-2015, 10:32 PM
  #119
Jesse's Avatar
What work are you having the shop do?
Old 02-23-2015, 11:09 PM
  #120
Slobodan Milošević
07blackg5's Avatar
Balance the rotating assembly, hone the block with a tq plate, line bore, and resurface the mating surfaces. And probably just assemble it while it's there and check all the clearances
Old 02-23-2015, 11:36 PM
  #121
Spawne32's Avatar
Any particular reason your line boring the mains? That's usually not standard rebuild policy.
Old 02-23-2015, 11:53 PM
  #122
Slobodan Milošević
07blackg5's Avatar
The guy just blasted off all of what was included in my quote. I am going to work out the details with them on sat. It's the shop that Arm recommended to me/uses (have done many ecotecs), so I would assume they know what's up.
I also drilled and tapped my manifold for a bleeder port. ZZP stealth has a fill cap and is very easy to bleed, so they recommend tapping the manifold for the bleeder. makes sense because it is the highest point of the system.
Marked by their procedure.
The crease seemed like a better point than the cross, so I punched my mark there.
Drilled a small pilot hole to reduce the risk of the drill creeping
Full size hole
1/8 NPT tap and drill bit
Tapped
You can see the location here. The hole is slightly off the very highest point, but it is very close. The manifold is slightly off angle so it looks a bit over-exaggerated, but it's pretty damn close.
I still need to clean the manifold, but I threaded in the nipple to see where I was at. It is snug here, but not vertical. once I add thread sealant and tighten it down, it should tighten up vertical. I just didnt want to tighten it down too much and loosen the threads.
Old 02-23-2015, 11:57 PM
  #123
Spawne32's Avatar
Good idea with the bleeder port, thats probably something I should do as well. It's been too cold in the garage to even bother with anything lately. lol
Old 02-23-2015, 11:59 PM
  #124
sandman's Avatar
shiny manifold lol
Old 02-24-2015, 12:03 AM
  #125
Slobodan Milošević
07blackg5's Avatar
i got it new from mongo after I smashed up the original one I had haha. The cores had metal shavings in them and were basically spot welded in with rust. I had to tighten down the hose clamps so much to keep them from sliding off that I collapsed the end of 2 cores. The fins were salvageable, but as I was cleaning them I realized that I has effed up the core ends. it was mild enough damage (didnt even notice until I was all done) that it probably would have been okay, but I didnt want to risk it.
I just said eff it and got a new one. It was an expensive mistake haha
Quick Reply: 07blackg5 Build Thread. Operation Moneypit
