08 2.2 airbox question
Old Dec 23, 2008 | 09:01 AM
Boomer's Avatar
I was going to build a cold air kit for my cobalt. The problem is the airbox it has a sensor. how do I get around this? Do I have to go buy a kit for the car or is there some way around this? thanks
Old Dec 23, 2008 | 09:31 AM
StrongIslandBalter's Avatar
Yeah cause we have SAI you have to buy the K and N short ram intake, you can pick it up at TurboTechRacing.com thats where i got myne
Old Dec 23, 2008 | 09:37 AM
Boomer's Avatar
ok thanks for the info, I will go there and get one.
Old Dec 23, 2008 | 09:39 AM
baggelis's Avatar
he's propably talking about the MAF sensor i thats correct to have to find someone or do it yourself if you can and weld a peice on the intake so u can screw the MAF sensor in place look around other people have done it if u have SAI is a different story specify which one are u talking about
Old Dec 23, 2008 | 09:43 AM
Boomer's Avatar
i believe its the MAF sensor. its the one on the back side of the air box lid.
Old Dec 23, 2008 | 05:52 PM
blackbolt89's Avatar
no, that's SAI. look up the sticky for SAI i believe that someone posted pictures. the MAF is on the hose. not the box. and don't listen to the person that claimed the only thing you can do is get K&N. i have SAI and went with injen instead. and just rigged up a breather filter on the SAI line and zip tied it to the passenger side screw for the airbox, closest to the edge of the engine bay. works fine and actually looks kinds legit. if you go this path you have to make sure that the SAI line doesnt rub against the alternator belt. but if you get the zip tie on good enough it won't move at all.
<a href="http://tinypic.com" target="_blank"><img src="http://i42.tinypic.com/30rqtxw.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Dec 23, 2008 | 06:54 PM
Boomer's Avatar
ill take pics of it this week and post them
Old Dec 23, 2008 | 11:44 PM
does your airbox look like this? if so you have SAI which will limit your choices of intakes ( unless you rig up something like mine) headers and just be a general pain in the ass.
https://www.cobaltss.net/gallery/fil...1Image0004.JPG
Old Dec 24, 2008 | 09:55 AM
Boomer's Avatar
yes its set up just like this. I wasnt seeing too much aftermarket for this car. Thats why I was glad when I found this site. So the headers and cold air kits are limited huh that sucks
Old Dec 24, 2008 | 10:51 PM
actually i think as far as headers you are screwed my friend. but as you can see you can set up a short ram. that filter in the back is on the end of the SAI line. that little angle pipe on your air box. its really not hard. you need any help you can just ask.
Old Dec 24, 2008 | 11:02 PM
BigTizzle903's Avatar
Intake your fine. Just disconnect the SAI (do a quick search there's a sticky somewhere about it) and throw a breather filter over it. However, if you are worried, K&N is the only company to make an intake with a port for the SAI so it will stay bolted into the intake.
Headers you at a loss for. However, as it is our headers are not all that restrictive, although aftermarket will produce a nicer exhaust note and power, the real exhaust restriction lies in the downpipe, which can be replaced no problem.
Old Dec 27, 2008 | 12:36 AM
SedanMan08's Avatar
i agree with blackbolt89, if you just get a breather filter and get a zip tie, and keep it away from your belts, you should be fine.
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
