2.2 to 2.4 Throttle body help !!!!!
Old Mar 28, 2009 | 10:10 AM
The Curly One's Avatar
I was going to install the 2.4 throttle body on my 2.2 today and do the Trifecta tune. I ran into a problem. The 2.2 TB has a 6 pin plug assembly and the 2.4 has an 8 pin assembly.
Does anyone know how to wire it.
The best thing would be a female to female adaptor so I could quickly change back and forth and there would be no wiring involved.
Please Help!!! Thanks in advance guys.
ilovecars's Avatar
huh.. bump for an answer.
Old Mar 28, 2009 | 10:28 AM
baggelis's Avatar
look around theres a thread about this somewhere
Old Mar 28, 2009 | 10:31 AM
Correction
I think I would like a Female to Male adaptor.
Old Mar 28, 2009 | 10:38 AM
chevysssc's Avatar
na lesbians are better
Old Mar 28, 2009 | 01:30 PM
hugemurph4's Avatar
what year r u
Old Mar 28, 2009 | 01:58 PM
2008
My car is a 2008 HHR with the 2.2 and I think the Throttle Body I got is a 2007?
Old Mar 28, 2009 | 04:22 PM
hugemurph4's Avatar
Yikes yea i heard they were differant...did u do any research before you did this...we all make mistakes
Old Mar 28, 2009 | 05:44 PM
I checked on here and some have done it
I checked on this forum and some have done it. I talked to Vince before I ordered the throttle body to make sure he could do the tune so we should be all good.
Problem is NOTHING goes right seems like.
I may have to keep the 2.2 TB and do a tune for it instead. Unless two of those pins on the 2.4 TB are not used for anything and I can get an adaptor.
Old Mar 28, 2009 | 06:22 PM
hugemurph4's Avatar
where did u get the throttle body and for how much cuz if it fits an 05 i might be able to take it off ur hands haha
Old Mar 28, 2009 | 06:30 PM
Find out if you have 6 pin or 8 pin plug
Find out if you have a 6 pin or 8 pin plug on your TB.
Old Mar 28, 2009 | 06:37 PM
CARLYLE's Avatar
just ask vince he knows how to do all that stuff
Old Mar 28, 2009 | 07:17 PM
blackbolt89's Avatar
by the way man you don't need to put a title for every post you make. lol
Old Mar 28, 2009 | 08:36 PM
hugemurph4's Avatar
well its dark right now and cold so i didnt feel like getting it off right now but i looked at it and i have 8 wires going into it so %99 sure its a 8 prong make sense right?
Old Mar 28, 2009 | 10:57 PM
I think if you have 8 wires then it should be a simple install and of course you would have to tune it for the larger TB. PM me on it.
Vince can help me with the program but I have to put the TB in there and it wont work with 8 pins on the TB and only 6 on my harness. Those two other pins go to something and the harness wont fit.
It appears I am going to have to find a 6 pin 2.4 TB (Do they make them?) or tune for the 2.2 TB.
Old Mar 28, 2009 | 11:35 PM
hugemurph4's Avatar
dude im sure you can find one with the 6 just find a later model balt they are called sport models instead of ss now haha stupid GMers personally i think ur only gonna find luck with the dealer and we all know they are goona rape you well maybe!!! but i will def get that off ur hands let me get some money together ok
Old Mar 30, 2009 | 08:16 PM
2007 ion2's Avatar
the year makes the difference, 06-07 2.2s and 2.4s share a connector, but I believe in 08 they changed it.
Old Mar 30, 2009 | 11:09 PM
HunterKiller89's Avatar
its a simple re-wiring. On the 8 pin, there are 2 low reference wires, and 2 5 volt reference wires. On the 6 pin, these wires are combined so there is only 1 of each instead. If you want to make a 6 pin connector, just combine them on your 8 pin connector (combine pin B and G, and combine pin C and H). If you want to make your 6 pin connector an 8 pin connector, just split the wires (i dont have the wiring diagrams for the 6 pin connector, so i dont know which ones to split)
Old Mar 31, 2009 | 02:12 PM
ScottxKillyou's Avatar
I already made a thread about this https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/lsj-throttle-body-l61-157541/
Old Mar 31, 2009 | 04:07 PM
2007 ion2's Avatar
or you could just do a little research for compatibility before buying random parts, I had to do the same thing because sometimes one year TB will be cheaper than another. mine uses the E67, so any 06-07 2.4 TB will work, but cobalts used two or three ECUs between the two engines and three years, complicating things greatly.
Old Mar 31, 2009 | 05:54 PM
the E37 was the 07-08, not 06-07. the E16a was used for 05-06
Old Mar 31, 2009 | 07:19 PM
2007 ion2's Avatar
my car is not a cobalt, on ions we had the E16 03-04, E37 05-06, and E67 07 2.2s and all 2.4s.
Old Mar 31, 2009 | 07:52 PM
I had done some research
I had done some research but I did not know that there were different wiring.
Anyway Vince at Trifecta does not have the plug for it but he is helping me get it running. Great service from Trifecta and I am very impressed.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
