2.2 Custom CAI Idea
Old Aug 31, 2006 | 03:09 PM
JRANGER's Avatar
2.2 Custom CAI Idea
Heres my idea. I have a short cold air intake from my old Dodge Ram. It has a good pipe on it that I will have to cut. My Idea is to remove the Clamp from the stock intake that connects to the filter. Cut the pipe to the right size to fit from that pipe to the filter box for my K&N. I will then drill holes to fit the MAF sensor onto the pipe. This way I can go back to stock with no problem. Just connect everything with the rubber sleeve and clamp it together.
You guy think this will work? Think it will look better then cutting the stock box to hell. Let me know what you think
Old Aug 31, 2006 | 08:44 PM
JRANGER's Avatar
common now people let me know. Im going to do this mod this weekend
Old Sep 1, 2006 | 02:15 PM
tonio5555's Avatar
It sounds plausible, but so far everyone I've seen do a custom CAI has ended up manhandling their stock airbox. Good luck and post pics!
Old Sep 1, 2006 | 11:29 PM
iLLmaTic3s's Avatar
i dunno bout that install..sounds a lil weird. i already made my custom CAI. sounds sick..responds amazing. this week ill be doing a ram air to it. tonio...hows ur exhaust goin..im thinkin for rite now to do 2.0 header and downpipe..ne thoughts? ill take pics of my intake when i do my ram air...i know u wanna see that. oh yeah i used that k&n e1009 filter..just like some ss/sc use...ill post pics soon.
Old Sep 2, 2006 | 01:26 AM
tonio5555's Avatar
Exhaust is going good so far *knock on wood* if the rain lets up tomorow I'm going to check it for leaks. I think the stock 2.0 exhaust manifold might be the same as the one used for the 2.2 and the 2.4 but I'm not sure. I posted a thread earlier about AEM or Injen for my intake, but I'm still thinking about doing a custom job. If it works just as well why spend $240 when I can get the same results for like $50.
Old Sep 2, 2006 | 10:27 AM
iLLmaTic3s's Avatar
yeah man it costed me 100 bucks. the filter was like 60-70 bucks...but it works really good.
Old Sep 3, 2006 | 02:52 AM
JRANGER's Avatar
Ok guys heres a little update for ya... I have sucess fully made my cai. My idea works great. I will be installing the intake tomorrow when the sealant finishes drying
Old Sep 3, 2006 | 08:40 AM
halfj99's Avatar
sounds good...hope ya dont throw codes
Old Sep 3, 2006 | 10:14 AM
iLLmaTic3s's Avatar
selant...wut r u using buddy? i throw no CEL's with my custom cold air intake. when we first started the car up it was running rough due to the air sensor being off for a hour...the t/c light was on. then we pulled over. turned off the car and turned it back on and it went away. its runs amazing....any of u guys want the idea or part numbers...let me know.
Old Sep 3, 2006 | 11:03 AM
JRANGER's Avatar
ya i used sealant around the hole i made for the MAF sensor so no air would leak out. I want to hear about your icustom and the aprts you used
Old Sep 3, 2006 | 11:20 AM
06blackg85ss's Avatar
I hope the sealant you used doesn't f with the mass air sensor... anything petroleum based with give off fumes and screw up the reading....
Old Sep 3, 2006 | 06:21 PM
JRANGER's Avatar
maybe thats my problem... sounds great but im throwing the Check engine light and traction control.....I used slicon sealant... What would you recomend using... I noticed when I had it on it was shifting gears real ruff too....I have an auto and it was jumping when shifting gear or even when I let off the gas...
Let me kow....I have enough piping to make another so when I get done and have no longer throwing CEL i will make another for someone..
Later
Old Sep 3, 2006 | 06:36 PM
Nickc84's Avatar
Granger I had the same exact problem when I made my intake. Traction control light was on and the tranny was shiftting gears superhard! the problem was the air gettin into the censor So I put duck tape around the air pockets and the traction light and jumpy gears havent happend in a over 6 months...
Old Sep 3, 2006 | 06:39 PM
Nickc84's Avatar
that other ss dudes right....the sealent you used mighta messed it up bro ..tape worked fine for me
Old Sep 3, 2006 | 07:44 PM
rally's Avatar
Hope you didnt damage the MAF in all of this, if you did have fun paying for the new one
Old Sep 3, 2006 | 09:16 PM
JRANGER's Avatar
no its fgine because i put the stock box back on and all is working great...Im going to use duck tape and see if it works...
THanks guys
Old Sep 3, 2006 | 11:50 PM
iLLmaTic3s's Avatar
wait did u cut out the mass air flow sensor??? and cut out a peice for it in the pipin for that old cai. on mine i kept that stock throttle body. no cel's wuts so ever. car runs amazin.
Old Sep 4, 2006 | 05:09 AM
JRANGER's Avatar
Yes, I did cut out a spot for the MAF sensor. Thats what the sealant is around. Tomorrow I am going to remove all the sealant and try to use duct tape. I would leave the bottom half of the box but my filter is to big. Im actually using a 3.5" pipe and K&N. (Old CAI form my dodge ram). I will let you guy know how it turns out.
Later
Old Sep 4, 2006 | 06:53 AM
RallyCobalt's Avatar
Lightbulb 2.2 Custom CAI Idea
Whoa Whoa man, you are making this ALOT harder than it should be. How Ironic this is going to sound probably complicated!
1. Get a 6" section of 3" exhaust pipe, about $3 if not free from any exhaust shop
2. Get your cone filter and a clamp for it
Now
Take the TOP part of your airbox off, you CAN remove the lower part too if you want, but this will work with or without it.
Now put the pipe in a vice..GENTLY, just enough to hold it still, put a thin block of wood inside the pipe near the middle and gently tap it with a hammer until it's flat, now take a little piece of rubber or gasket material and cut out the shape of the MAF. MAKE SURE that the MAF is mounted the same direction as the seam in the exhaust pipe because if it's horizontal and the seam is vertical, well your air isn't gonna flow into the sensor. Now slide your sensor in, use some tiny selftapping screws, make sure the FILTER side has the opening for the MAF showing. Now slide the filter on, slide the pipe in the stock rubber intake pipe and BOOM.
SHORT RAM.
If your going cold air...Get some 3" dryer ducting ($5), if you want, paint it black or hightemp or whatever and then get the same 6" section of pipe and cut/place the stuff where you need it.
I had just the short ram w/ stock lower airbox, pulled the lower part out..then decided to just use dryer ducting i had laying around instead of the big plastic part over the throttle body..and it works GREAT. I'll get pics for you. Email me at Piercingpsycho@aol.com.
It may sound complicated, but it's REALLY easy.
Old Sep 4, 2006 | 08:48 AM
iLLmaTic3s's Avatar
hopefully u didnt mess up that sensor.
Old Sep 4, 2006 | 09:40 AM
JRANGER's Avatar
ya only thing i did was use the wrong sealant everything else is about the same other then my 3.5" piping.. im positive i didnt mess up the sensor because i didnt drive far with it on and then oi put the stock air b ox back on and alol my CELS went right off
Old Sep 4, 2006 | 10:31 PM
iLLmaTic3s's Avatar
keep u keep the stock airbox?
Old Sep 5, 2006 | 02:52 PM
JRANGER's Avatar
yes my stock airbox is fully intact...and I just ordered a new airbox and filter. I have given up on this diea because I feel the Filter I have is worthless. I cleaned it inproperly and probably ruined it. I believe that is my prob. However i am now going to make a full intake with the airbox I just ordered. Im getting a AEM filter so I think I will work out great. Ill let you guys know how it goes and take pics for when it is done. Then I will make a DIY if it works out eprfectly
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
Oct 20, 2015 09:56 PM
Tupp
Sep 30, 2015 08:18 PM
