2.2 Emissions Issues?
Old Oct 4, 2009 | 03:34 PM
tonio5555's Avatar
I posted this letter I got in the Problems and Service board, but I thought it'd be helpful to post it here too.
Old Oct 4, 2009 | 04:30 PM
Spanky's Monkey's Avatar
i got one too, means absolutely ****. just gm covering their ass'.
Old Oct 5, 2009 | 12:15 AM
06_ion2's Avatar
if i got one of those for my ion i would be fucked if they had to do a inspection
Old Oct 5, 2009 | 08:15 AM
i doubt it unless you're showing codes. you can essentially trick those scanners either way, showing a pass code or by having codes shown that aren't actually set.
Old Oct 5, 2009 | 08:19 AM
jonxxxedge1's Avatar
im a 2006 and i dident get one yet. hmmm
Old Oct 5, 2009 | 10:54 AM
06_ion2's Avatar
if all they do is check for codes then im good. i know if they look at other **** id fail.
Old Oct 5, 2009 | 11:00 AM
round here they're lazy and if they don't see a cel and they get a pass code, you're on your way.
Old Oct 5, 2009 | 07:38 PM
YSUsteven's Avatar
I got one of those letters too, by mine passed inspection fine last spring.
Old Oct 5, 2009 | 07:42 PM
Jn2's Avatar
Jn2
i got one too...second o2 is disabled, so it will not throw a code, lol i dont even have a second o2 to begin with
Old Oct 6, 2009 | 03:20 PM
tonio5555's Avatar
For states without exhaust sniffers... no code = passed inspection?
Old Oct 7, 2009 | 05:24 PM
flyg5's Avatar
so do we actualy need that second o2 sensor?
Old Oct 7, 2009 | 05:26 PM
D4u2s0t's Avatar
You have to have no code, and the monitors have to be set to ready. Meaning if you have a code, and just delete it with a code reader, that will set the monitors to not ready and you will fail. I just went through that fiasco.
The rear 02 sensor is only used to make sure your cat is operating correctly. If it was disconnected, or broken, you would have no way of knowing othe than having a cel. The car won't run and/or drive any differently.
Old Oct 7, 2009 | 05:41 PM
06_ion2's Avatar
unplug the battery then for like 15 min and go there. cleared codes!
Old Oct 7, 2009 | 05:43 PM
D4u2s0t's Avatar
even if the codes are not there, the monitors show up as "Not ready". You will fail for having monitors set to not ready. They will tell you to come back after a few drive cycles. Once the monitors ready "ready" the code will come back.
Jn2's Avatar
Jn2
the snifers are for obd1 cars, if your obd2 they just connect to the port and go off what it says, if you turn off the CEL off there is no worries...im not even running a second 02 sensor on mine, i have a 02 plug on it, and left the pigtail on the engine harness hanging down, second o2 is somewhere in the garage, no CEL, passed inspection just fine, reseting the ECM or clearing a code doesnt hide it, you have to turn it off via tuning software...
Old Oct 7, 2009 | 05:45 PM
D4u2s0t's Avatar
this is exactly right, but to clarify for those that don't fully understand: resetting the code with an obd2 scanner is not the same as TURNING IT OFF with a tuning program. In order to pass, it needs to be turned off, not just erased.
Old Oct 7, 2009 | 05:47 PM
Jn2's Avatar
Jn2
yup...i dealt with this a lot when i used to work at autozone, people would want me to turn it off via obd2 scanner, id tell them it will show as "not ready" and fail them...
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
