2.4 mani problem
Old Aug 20, 2009 | 03:30 PM
JSneeks's Avatar
2.4 mani problem
Ok, so I tried to search but it wouldn't find anything for me. So I'll ask you guys here.
I've had a 2.4 mani on my 2.2 for about a year now, no problems with no tune either. So the other day a buddy of mine does the swap, and his CEL comes on. We check it and its throwing the P0171 code, saying its running lean. Would the 2.4 mani cause that? Thanks in advance.
Old Aug 20, 2009 | 03:39 PM
Spanky's Monkey's Avatar
did he **** up his maf or install it backwards?
Old Aug 20, 2009 | 03:49 PM
JSneeks's Avatar
hmm... I'm not sure about that. Is there an easy way to see if the maf has been damaged or installed backwards?
Old Aug 20, 2009 | 04:35 PM
best advice carefully remove yours and examine it and then check out your friends.
Old Aug 20, 2009 | 05:28 PM
JSneeks's Avatar
ok makes sense. he should be ok driving lean for a few days? seeing as how he lives a good distance away.. it's a pita to get there
thank you much for the quick reply spanky!!
Old Aug 20, 2009 | 09:38 PM
XM15's Avatar
He should be fine. I drove for a year with an intermittent lean code.
If he gets a Trifecta tune, that should fix the code though. It fixed a couple of mine.
Old Aug 21, 2009 | 12:39 AM
zack93's Avatar
what are the advantages of running the 2.4 intake on the 2.2? By switching to the 2.4 mani could u still run a cai based on the 2.2?
Old Aug 21, 2009 | 12:42 AM
HatedCobalt's Avatar
add power and torque for such a little mod. and yes you can run the same CAI.
Old Aug 21, 2009 | 12:49 AM
ionit3's Avatar
i did it and got the lean code. i took it off cuz it kinda bothered me lol. i never really figured it out im gunna try again soon though
Old Aug 21, 2009 | 01:14 AM
zack93's Avatar
okay thanks guys.
Old Aug 21, 2009 | 02:14 AM
NWAE Cobalt's Avatar
it means that you have a vac leak...your not sealed somewhere on teh intake...
Old Aug 21, 2009 | 04:12 PM
JSneeks's Avatar
is there some way to tell exactly where the leak may be? thanks again for all the help guys.
Old Aug 21, 2009 | 07:44 PM
only way i know of would be smoke, itll get sucked in somewhere and yu have your answer...although just start messing with stuff till its fixed
Old Aug 24, 2009 | 01:23 AM
blackbolt89's Avatar
never had a lean code with my mani til i got it tuned. my vote is for a leak.
Old Aug 24, 2009 | 01:27 AM
SportRedLT's Avatar
my vote isss your moving in more air into the engine then what it stock would do thus making it run more lean(more air compared to the same fuel) i got that code too i dont think hes running dangerously lean by any means at all the computer is just picking up on it a tune will fix it but im sure your fine. it could be any one of what other people said too i suppose but from my experience thats what it was
Old Aug 24, 2009 | 03:35 AM
playing it with :i dont think it is too lean: will get your nothing but a blown engine...
ANY lean is too lean unless you have a wideband and can check
i would check ALL fittings, and im willing to bet its the break booster hose, and then reset the codes by unplugging the battery for a few min...if it comes back then get a code reader and double check everything
? for you, what year balt and did you use/need an adapter plate for the tb???
Old Aug 24, 2009 | 09:45 AM
SportRedLT's Avatar
2008 so no plate and i agree def check into it for sure always better safe then sorry i just freaked out when i got the code i took of the mani and reinstalled it about 3 times till i realized that just might be it. after a week or so it did go away but again every car is different and it hasnt returned since i had gotten my tune.
Old Aug 24, 2009 | 11:34 PM
tru2nrtt777's Avatar
Although I vote leak too that is not entirely true, you can find a shop who has a snap on Motis or the previous snap on obd2 scanner and run it at different rpms with the scanner datalogging the afr's. As long as it isnt too bad and you reset your short term and long term fuel trim it should correct for the better flow but it wont if there is a leak because your maf is reading one thing and the o2 is reading something different.
Old Aug 25, 2009 | 12:15 AM
Kodatech's Avatar
I think there is something wrong here, I have been running a cat-back, CAI, and the 2.4 manifold for a few thousand miles with no tune, and no check engine light.
Old Aug 25, 2009 | 12:45 PM
Well our cars are tempermental, for some people they can fart and trip a CEL
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
justinchinn
Oct 2, 2015 12:18 PM
Stuff
Oct 1, 2015 05:47 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
