2006 lt headers?
Old Apr 15, 2008 | 10:31 PM
xplayer325's Avatar
2006 lt headers?
ok I was wondering what the best sounding and HP increase header is out there.
Old Apr 15, 2008 | 10:38 PM
yellowltcoupe22's Avatar
any header will work if you dont have sai. but it all depends on what rpm range you wantin the power to be in. short gives you power in the low rpm mid lenght gives it in the mid rpm and long gives the top end power.. i would say go with the zzp header down pipe combo though.. it seems to be bout the best and thats what im bout to get too.
Old Apr 15, 2008 | 10:40 PM
XM15's Avatar
Reverse those. I used to think that too, but after a little research I found out the opposite is true.
But like yellow said, where do you want your power band?
xplayer325's Avatar
where do you get eh zzp header and down pipe from? and thanks for the quick reply
Old Apr 15, 2008 | 10:41 PM
XM15's Avatar
Get them from ZZP.
They are in the supporting vendor index.
Old Apr 15, 2008 | 10:44 PM
lol yeah i knew it goes somethin like that.. guess im just basshole ackwards tonight.. but yeah get em from zzp..
Old Apr 15, 2008 | 10:46 PM
XM15's Avatar
Well, you can't go wrong by saying the midlength will help your midrange. lol
I think the movement of the powerband with a header has to do largely with resonance, which I'm not completely clear about.
Old Apr 15, 2008 | 10:54 PM
lol very true..
Old Apr 15, 2008 | 11:14 PM
xplayer325's Avatar
so if your cut your resonater off is that bad
Old Apr 15, 2008 | 11:17 PM
ScLsN00b's Avatar
no, thats not bad,
just not the cat,
Old Apr 15, 2008 | 11:24 PM
xplayer325's Avatar
ok so with the zzp combo what kind of options should I get. like these sizes mean nothing to me I know I want a 2.5 in. exhaust so I know that but the O2 sensors and the first option are a little over my head
Old Apr 15, 2008 | 11:27 PM
o3nisoaso3's Avatar
check it out....
https://www.cobaltss.net/forums/parts-66/cobalt-addiction-v1-header-fs-104921/
https://www.cobaltss.net/forums/parts-66/fs-vibrant-header-dp-combo-106045/
Old Apr 16, 2008 | 04:34 PM
xplayer325's Avatar
ok so I have been looking and are the DC sport headers any good at all
Old Apr 16, 2008 | 07:58 PM
TurboTechRacing's Avatar
Dont go with the DC Sports, it was designed back in the day for the cavalier, and IMO and other cavalier owners not worth it.
You can also check out Pacesetter and the Vibrant header/down pipe/high flow cat setup @ www.TurboTechRacing.com
Old Apr 16, 2008 | 08:36 PM
07lsdh's Avatar
But don't you have to cut your downpipe for the pacesetter? Is there any other header that bolts to the factory downpipe?
Old Apr 16, 2008 | 10:05 PM
XM15's Avatar
I believe Cobalt Addiction sells one.
Old Apr 16, 2008 | 10:14 PM
yeah ca has one but if your gonna put a header on why keep the stock down pipe? you wont see much of an improvement doin that cuz your opening up the header by puttin it on then funneling it all back down goin through the factory dowm pipe and restrictive as hell cat... get the header down pipe combo and be done wit it..
Old Apr 17, 2008 | 01:00 AM
07lsdh's Avatar
I've got an LSJ downpipe, it's quite an improvement from my puny ls donwpipe. Plus i dont want to spend a lot on a header dp combo.
Old Apr 17, 2008 | 01:02 AM
o3nisoaso3's Avatar
you can get the dp from CA cheap and i got their header for sale
Old Apr 17, 2008 | 09:44 AM
RedBaseBolt's Avatar
I have the ZZP header and downpipe installed on my car.
It makes a VERY noticable difference in power both low end and upper RPM range.
I had to have it modified to fit the 2.2 by flattening the first runner though since it's not designed for our cars as I found out during the install.
After being made to fit I am very pleased with it.
I don't throw a CEL either.
Here are some pics.
Old Apr 17, 2008 | 09:22 PM
how bout a pic of what you had to mod to make it fit?
Old Apr 18, 2008 | 12:03 AM
07lsdh's Avatar
Is it the V1 or V2? Because i have read that the V1 won't quite fit right on our cars, and that the V2 has too large of a collector to be of any use.
Old Apr 18, 2008 | 12:33 AM
o3nisoaso3's Avatar
its the V1... itll fit 06 and newer 2.2s with just a little dent in the coolant line that goes from the thermostat housing to the firewall. (the 05s with the newer style motor mount should fit too... i got the older style)
Old Apr 18, 2008 | 02:53 AM
Jn2's Avatar
Jn2
i have a stainless steel header, looks nice, i have that a custom dp, 2.25" all the way to the exhaust, lemme nab a pic from my gallery
agentirons
Oct 16, 2015 02:11 AM
patooyee
Oct 15, 2015 05:11 PM
dieGone
Oct 1, 2015 06:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
