About to do cams
Old Feb 19, 2012 | 07:29 PM
KingSal's Avatar
About to do cams
About to install some cams on my 2.2, any advice on brand/make or stage to go with?
Old Feb 19, 2012 | 07:31 PM
BankerBalt's Avatar
do you have full intake/exhaust?
Old Feb 19, 2012 | 07:36 PM
StevesBlack06's Avatar
zzp carries grinds from comp
Old Feb 19, 2012 | 07:40 PM
KingSal's Avatar
yeah i have full bolt ons, 2.4 mani and all
Old Feb 19, 2012 | 09:34 PM
BankerBalt's Avatar
Stage 2 if you're looking for a bigger increase. Will have to do valve springs though
Old Feb 19, 2012 | 09:43 PM
and imo zzp valve springs are junk. go with supertech
Old Feb 19, 2012 | 09:51 PM
BankerBalt's Avatar
I never said anything about zzp in this thread?...
Old Feb 19, 2012 | 10:40 PM
KingSal's Avatar
Cant find 2007 2.2 cams anywhere...
Old Feb 19, 2012 | 10:52 PM
yes, im aware of that... i was just adding to what you said.
Old Feb 19, 2012 | 11:01 PM
bluebalt07's Avatar
TTR has cams for the 2.2
BankerBalt's Avatar
Cams aren't made specifically by year, but type of engine
Old Feb 20, 2012 | 12:57 PM
MadBrad's Avatar
07-08 L61's are not direct bolt on's like the 05-06 engines. If I remeber correctly the intake is a direct replacement, but the exahuast requires you to fit the sensor on the end of the cam. This requires having a machine shop to cut off extra material, and then making sure that you have everything line up correctly. It's been done before. Heck those cams might still be floating around here someplace.
https://www.cobaltss.net/forums/2-2l...7-cams-122345/
Old Feb 22, 2012 | 12:35 PM
TurboTechRacing's Avatar
Yes we do springs and valves too!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
