Aftermarket Tach Install Question
Im planning on doing some road course driving this summer so I went out and got a small aftermarket tach so I dont have to constantly look down. Can I just splice into the back of the guages since there in a tach alreaddy on it? And if so what colors are what?
you won't get an accurate reading doing that....the stock tach is about 100-150 rpm off at idle and up to 500rpm off on the high end (5k-6.5k)....best bet is to just install the aftermarket according to manufactures instructions you will get the most accurate reading possible....
I have a 2" tach in my SS/SC Pillar and it reads exactly 100 rpm off but it's definetely not off in the high end 5-6k rpms. I don't know maybe that's only if you splice into you stock tach wires.
I'm running the MSD Tach Driver that gets a signal right from the ICM and creates a tach signal that you can use with any aftermarket Tachometer
my car's tach says it idles around 825-850 but when i had the inspection done it was idling at 773....and i know that the engine redline on the 07 is around 6200 but my tach will show that i can hit 7k....and it's notoriously know that stock tachs are always inaccurate that's why many people that actually race for a living always have an aftermarket tach installed for the most accurate reading....
i noticed the other day the car felt like it was "camming" basically idle low then idle a little higher (you can tell because the car makes a different sound and it vibrates a bit more) and the tach didn't move at all...but the vacuum gauge was jumping to the synch of the vibration....
if i think about it later i will take a video of it...
Yes he is right about 1 of 2 things
just set the cylinder output to 2 and you get the proper reading...just FYI for anyone wondering
The Steward Warner Digital Tach was all I could really find that had 1 to 12 Cyl. option
hmm, my Zex window switch and Raptor shift light both have a 2 cyl mode so no probs for me
