ahhhh wont start!
Old Oct 6, 2011 | 06:20 PM
Bl@ckC0balt's Avatar
ahhhh wont start!
ok my 2.2 sc ls wont start..... again ... first it was because I didn't wire the lsj throttle body. well all that said and done it started right up. I was waiting for the tune in the mail and when it came I loaded it and now it wont start again any suggestions?
it does click when I turn the key just never turns over.
Old Oct 6, 2011 | 06:57 PM
BLKLS's Avatar
Battery?
Old Oct 6, 2011 | 07:14 PM
battery is 100% and good checked at autozone
Old Oct 6, 2011 | 07:29 PM
night_throne's Avatar
if ur using trifecta email vince see if mabey its a problem with the tune
Old Oct 6, 2011 | 07:48 PM
I contacted Vince and he said tune was fine:/
Old Oct 6, 2011 | 07:50 PM
Kyle4236's Avatar
wrong vin enetered in the tune?
Old Oct 6, 2011 | 09:27 PM
ben_gary's Avatar
check battery terminal connections for loose or if corroded. if automatic trans- not completely engaged in park. starter motor pinion jammed on flywheel. starter solenoid faulty or starter motor faulty. check fuse or relay switch
Old Oct 7, 2011 | 06:22 AM
huckernage's Avatar
when you start your car the first time. did you have your stock injector.
if not. check your spark plug. never run 42lbs+ on tune stock. it ll spray a ton of fuel in the chamber.
Old Oct 7, 2011 | 08:50 AM
I think its my starter
Old Oct 7, 2011 | 08:11 PM
ben_gary's Avatar
did you test the starter solenoid by- connecting a test light or voltmeter to the starter solenoid switch terminal (small wire) while someone turns the ignition switch to the start position. if no voltage check wires. if there is voltage then can check the starter by- try doin' a jumper (old school way- use a long screw driver and place between the positive terminal and the B+ terminal on the starter). if turns then bad solenoid, if nothing then the starter is bad.
Old Oct 7, 2011 | 11:19 PM
well I got under the car and one of the terminals and broke:/
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
