LNF exhaust
LNF exhaust
Will an LNF exhaust system fit a 2.2 L61 motor? I'm thinking about buying one but I'm not sure if I can directly mount it onto my exhaust, does anyone know if it is possible! Thanks!!
not sure but should be do-able.....compare the mounting points of the two systems and look at the routing to check........if something is a problem or a little tight somewhere im sure a muffler shop and get it to work for cheap
Well that would be a good alternative but do you know if the bolts on the headers will match up? And in the picture it looks like it'll be the same routing but I'm not too too sure
patooyee
Oct 1, 2015 01:07 PM
