LNF exhaust
Old Oct 10, 2011 | 04:02 PM
AcyclicCobalt21's Avatar
LNF exhaust
Will an LNF exhaust system fit a 2.2 L61 motor? I'm thinking about buying one but I'm not sure if I can directly mount it onto my exhaust, does anyone know if it is possible! Thanks!!
Old Oct 10, 2011 | 04:12 PM
jg707's Avatar
not sure but should be do-able.....compare the mounting points of the two systems and look at the routing to check........if something is a problem or a little tight somewhere im sure a muffler shop and get it to work for cheap
Old Oct 10, 2011 | 04:47 PM
Well that would be a good alternative but do you know if the bolts on the headers will match up? And in the picture it looks like it'll be the same routing but I'm not too too sure
Old Oct 10, 2011 | 04:55 PM
06_cobalt's Avatar
Flanges are different
Old Oct 10, 2011 | 08:41 PM
VRCobalt's Avatar
^^What he said. Flange bolt pattern is different. Also, keep in mind that the tip hangs lower b/c SS have lips.
Old Oct 10, 2011 | 09:14 PM
znew's Avatar
i have it on mine. just had a different flange mounted on the end.
Old Oct 10, 2011 | 09:15 PM
TurboTechRacing's Avatar
3 bolt VS 2 bolt is needed...
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
