Another 2.4 Throttle Body ???
i have a 2005 2.2l L61 with only a SRI. waht do i need to do inorder to do this?? i know a i need a tune afterwards. Someone Please inform me. i have read so many damn threads on this subjuct i dont know what is true and what is not.
Will this work for my car??http://www.zzperformance.com/cobalt_...=999&catid=174
You don't want that.. Thats not for the 2.2l or the 2.4l.
You have an 05 so you have probably 8 pins which means you'll need an 8 pin TB from a 2.4l cobalt.
https://www.cobaltss.net/forums/show...=180572&page=2 - You need a TB from an 05-07 2.4l cobalt.
The 2.4L cobalts TB bolts just fine to the 2.4L cobalts intake manifold. With a plate the 2.2L cobalts TB bolts to the 2.4L cobalts intake manifold. If you're asking if the 2.4L cobalts TB will work on the 2.2L cobalts intake manifold I dunno.
from what ive done with mine you need to change the intake manifold as well..get yourself a 2.4 manifold and 2.4 throttle body and then you will need a tune. im waiting a while before i put on the 2.4 TB so i used my 2.2 TB and i felt a nice gain from just the Intake Manifold
Go to crateenginedepot.com -- they have a complete 2.4L intake kit for the 2.2L engine. You can also buy the TB from them.
I am getting the 2.4 intake manifold and the 2.4 TB very soon
Do i need a different gasket since i am using the 2.4 throttle body also?
here are the part #'s i have
LE5 Intake Manifold (Part# 12587878)
PVC Seal (Part# 12589516)
Extended Brake Hose
Throttle Body Seal (Part# 12600729)
Bump! I don't want to have to make a new thread!
Extended Brake Hose
Extended Brake Hose
Extended Brake Hose
Would you or anybody happen to know the part # for the 2.4 throttle body gasket? I found the 2.2 gasket on GMPD but couldn't find the 2.4 gasket.
