Blown engine / Core engine pictures
Old Jan 24, 2006 | 12:57 PM
Halfcent's Avatar
I'm old school
Here is my engine back when the valve spring broke and tore up my first engine.
On this one, notice how the valve seat is gone. The valve knocked it right out of the head when the piston jammed it on the up stroke.
Then on this one, you can see a broken lifter jammed in its boss, right next to a normal lifter still sitting next to it on the bottom row (exhaust side).
Then I have pics of a now disassembled core engine. I don't have the head anymore because it is being installed on my old engine to replace the destoyed one. Here is the case from the bottom;
On this one of the lower crankcase/girdle you can plainly see the cast-in dimple for a turbo oil return line.
All the major sub assemblies except for the head;
Here is the timing end of a crankcase. The large hole on the left is the water pump mount. The two smaller holes are the balance shaft bosses.
I also got a valve cover with the core, so I'm polishing it up. Here is its so far. I have cleaned it using Nylox brushes and drill. I need to get a smaller cup brush to get into the ignition module channel.
Old Jan 24, 2006 | 01:06 PM
ecoteched's Avatar
Sorry to hear about the engine, but atleast you get a nice project now.
Old Jan 24, 2006 | 01:08 PM
love my SS's Avatar
how many miles was on this when this happened and was you driving it like you stole it? warrenty work i hope?
Old Jan 24, 2006 | 01:18 PM
Halfcent's Avatar
I'm old school
This is actually old news for me, I'm just getting the pics up now. You can read about the story here:
Halfcent's Horror Story!
Old Jan 24, 2006 | 03:08 PM
celicacobalt's Avatar
nice polish job
Old Jan 24, 2006 | 04:07 PM
Cobalt443's Avatar
I also blew my motor with only 381 miles on it....to be more specific, i cracked the block, warped the head, and melted the number 4 piston.......i did a pretty good job with it....hehe
Old Jan 24, 2006 | 05:14 PM
WopOnTour's Avatar
1/2
FYI
I've seen damage identical to this caused by a mis-assembled roller follower after a cam R&R. The follower has a notch/groove that must be properly aligned onto the tip of the valve step, as the cam is initially torqued down or it may "****" off to one side.
After the initial first pass tightening it's important to visually inspect each roller follower to make sure it hasnt cocked. The intake side is especially difficult to see when this is assembled "in-car" as you need to practically lay on your side, on top of the fender to inspect the lobe to roller alignment. From above- it's easily missed.I guess it could have dropped a keeper...
I suspect the broken spring was after the fact as well
What cam lifts are you using?
WopOnTour
Old Jan 24, 2006 | 06:06 PM
Brian MP5T's Avatar
Originally Posted by WopOnTour
1/2
WopOnTour
He said Stock Cams
Old Jan 24, 2006 | 06:32 PM
Halfcent's Avatar
I'm old school
Correct, stock cams at the moment. The aftermarket cams I have seen are not street legal, and a street legal car is my goal. I am using Ferrea valve train components on the new head assembly. They allow a lift of up to .5. Since the cams on the ecotec are replaceable without taking off the head, it allows me to upgrade them later with ease.
Old Jan 24, 2006 | 10:54 PM
Nocturn's Avatar
So I missed part of the story, are they building you a new one?
Old Jan 25, 2006 | 07:58 AM
3fo893013L's Avatar
With the amount of time invested in this I would scrap the project for now. Who knows.. hopefully things turn out and it can get built the right way this time..
Old Mar 5, 2006 | 03:19 PM
tallyphotog's Avatar
ouch.. call Triple-A cuz you need a tow.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
