Bought Wrong Turbo is Project Ruined?
Old Mar 16, 2011 | 12:27 AM
Axelthered05's Avatar
Ok so like 3 months ago I bought a turbo that was supposed to be a GT28 turbo got it took it out of box and everything looked astatically pleasing so I went about buying parts for my custom kit made a downpipe purchased oil supply and return lines and all that important stuff but when I went to go check the fitment of the oil return flange it didn’t fit which was my first red flag since I ordered it specifically for the turbo then I notice the A/R markings on the exhaust housing and my heart sank, what was supposed to be an A/R of .64 for the turbine was marked as .86 So somehow I ordered or ended up with the wrong turbo. I’m no expert but to me a high turbine A/R yields slower spool time. My question is can I still use this turbo effectively or is my project dead in the water?
the specs of the turbo acording to the part number on the housing are 0.42 A/R Compressor, 60mm/42mm Compressor Wheel, 0.86 A/R Turbine, 53mm/46mm Turbine Wheel
Old Mar 16, 2011 | 12:39 AM
any imput anyone?
Old Mar 16, 2011 | 12:40 AM
N1ckateen's Avatar
free bump
Old Mar 16, 2011 | 12:59 AM
Originally Posted by N1ckateen
free bump
thanks!
Old Mar 16, 2011 | 02:02 AM
Come on someone with some turbo info advise me
Old Mar 16, 2011 | 02:22 AM
stoon_cobalt_colby's Avatar
.63 will spool alot faster than .86 will take along time to spool im pretty sure but not positive
Old Mar 16, 2011 | 08:24 AM
so basicly their is no point in continuing with this turbo :insert big sigh here:
Old Mar 16, 2011 | 08:33 AM
Chevycobaltss3's Avatar
spool time is a + but when you create a better flow maning a bigger a/r it can create better effieciency. So i deal with your turbo and begin everything order the correct stuff.
Old Mar 16, 2011 | 10:01 AM
so how do i make an efficient system using this turbo?
Old Mar 16, 2011 | 10:06 AM
BLAZIN07SS's Avatar
I'm too JDM for you
it will still work. you could buy another turbine housing for example if you wanted. what flange does the turbo currently have?
i know atpturbo.com has some turbine sides for the gt28's
Old Mar 16, 2011 | 10:16 AM
it curently has a T25 inlet flange with a 5 bolt with a v band atachment outlet
Old Mar 16, 2011 | 10:38 AM
i really dont want to spend another 300 on a turbine housing so if posible i want to make this work
Old Mar 16, 2011 | 11:15 AM
BLAZIN07SS's Avatar
I'm too JDM for you
it will work fine. it will just spool a little slower. it's a relatively small turbo anyway
Old Mar 16, 2011 | 02:18 PM
well thats a sigh of relief
Turbo Johnny
Feb 21, 2019 09:41 AM
ricklovin93
Aug 27, 2016 06:35 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
dieGone
Sep 23, 2015 10:20 AM
ashalle2
Sep 16, 2015 10:36 PM
