Building the head
Old May 14, 2012 | 11:22 PM
BankerBalt's Avatar
Building the head
due to me screwing my engine completely.... is this everything that i'll need to get the head built aside from cams?
Old May 14, 2012 | 11:34 PM
bluebalt07's Avatar
Get new valve seals too. Also depending on the damage you did, you may need new rockers and lifters too. What happened to your engine?
Old May 14, 2012 | 11:41 PM
BankerBalt's Avatar
i know stems. the only concern is that it states in the kit that i need smaller stems... i guess i'll figure that out. i don't believe i blew a rocker or lifter, but would there be a way to know that?
that's what happened lol
Old May 14, 2012 | 11:46 PM
AzraelRaezier's Avatar
"final carnage... 3 blown pistons, spun bearings, all of my valves need to be replaced. 3k just turned into 5k. why? because racecar" his post on fb
Old May 14, 2012 | 11:51 PM
BankerBalt's Avatar
i'm not friends with everyone on facebook broski... the parts for the head that i put up are AFAIK, stock replacements.. can everyone validate that?
Old May 14, 2012 | 11:52 PM
i know. i just didnt feel like typing so i copy-pasted. im friends with both of you on facebook lol
Old May 14, 2012 | 11:58 PM
bluebalt07's Avatar
Damn dude that sucks. If the rockers and lifters are still where they should be then you shouldn't need to replace them. You will have to bleed the oil out of the lifters before reinstalling them though. Curious about how all that damage occurred.
Old May 15, 2012 | 12:04 AM
BankerBalt's Avatar
we've discovered that.... bad fuel pump = bad detonation
Old May 15, 2012 | 12:14 AM
bluebalt07's Avatar
Wow never would've thought losing fuel would cause so many problems. Sorry to hear man
Old May 15, 2012 | 12:18 AM
BankerBalt's Avatar
this happened a month and a half ago lol... i just pulled the engine yesterday and took it apart within an hour this morning. nobody has answered my question yet! i'm looking for a stock replacement with all supertech... are those parts good to go for replacement or should i be looking at different part numbers?
Old May 15, 2012 | 12:25 AM
bluebalt07's Avatar
Couldn't tell you because I can't really tell what you're getting by looking at the picture. As long as they are for a cobalt they will work in your stock head.
Old May 15, 2012 | 12:28 AM
BankerBalt's Avatar
Supertech Spring / Retainer Kits CHEVROLET CAVALIER BASE 2002 - 2005 2.2 SPRK-EC3027
Supertech Valves CHEVROLET CAVALIER BASE 2002 - 2005 2.2 GIVN-0010
Supertech Valves CHEVROLET CAVALIER BASE 2002 - 2005 2.2 GEVN-0010
those are the parts..
Old May 15, 2012 | 12:39 AM
bluebalt07's Avatar
Yep those will work for you. I'm not sure what the deal is with the smaller seal though
Old May 15, 2012 | 12:54 AM
BankerBalt's Avatar
Awesome thanks!
If you look at the description for the seats, it says it requires smaller seals.... Insight anyone?
Old May 15, 2012 | 05:33 PM
BankerBalt's Avatar
New plan...
Zzp 82# springs and retainers
Supertech intake valves
Supertech exhaust valves
Supertech valve guides
Supertech valve seat
Viton valve seals
Good plan? All compatible?
Old May 15, 2012 | 06:43 PM
bluebalt07's Avatar
Sounds like a good plan. Only thing I'd ask about is wherever you buy the seals from, I'd ask them if they work with the supertech valves
Old May 15, 2012 | 06:59 PM
BankerBalt's Avatar
I bought the seals from dezod. And in the supertech valve guide description, it says that those are required to work with the guides. Assuming that all supertech parts are compatible
Old May 15, 2012 | 10:21 PM
BankerBalt's Avatar
can someone please explain to me which supertech spring seats will work with zzp's 82# valve springs and retainers?
Old May 15, 2012 | 11:10 PM
BankerBalt's Avatar
i'm trying to buy parts like...right now... anyone?
Old May 16, 2012 | 10:31 AM
BankerBalt's Avatar
Bueller, bueller?
Old May 16, 2012 | 10:58 AM
Brags's Avatar
I think I might be one of only a few l61 with fully built, port polished head. I am running the Supertech #78 springs, Ti retainers, custom seats, Supertech coated valves, and 5 angle race port and polish from Performance Autowerks. We thought this would be plug and play for stock, but was not. The stock size valves are fine, but custom work to head and seats is required. IF need more exact information, I would contact my man Dave or Ricky at PWerks in Plainfield, IL.
Old May 16, 2012 | 11:46 AM
BankerBalt's Avatar
So the supertech stock size valves will not fit?
Old May 16, 2012 | 12:04 PM
Brags's Avatar
Valves are fine, its the 78# supertech kit that needs custom work to head and seats. I think you should be fine with zzp, but I would ask them.
Old May 16, 2012 | 12:10 PM
BankerBalt's Avatar
Alright phew! Do you happen to know what seats would work with zzps springs? They aren't getting back to me at all right now...
Old May 16, 2012 | 10:23 PM
06_ion2's Avatar
I just bought a patriot head so i didnt have to deal with all this.
