building the motor!
Old Jan 3, 2012 | 05:28 PM
killswitch1209's Avatar
building the motor!
Question I'm planing on building it I'm doing e85, pistons (8.5.1), eagle h beam rods, cometic headgasket, arp headstuds, rod bearings what els should I do while the motor is appart was thinking water pump and ya injectors are nessisary for e85 and the power I'm going for and then tune but ya what els u think??
Old Jan 3, 2012 | 05:45 PM
kxrida2000's Avatar
new timing chain kit fo sho, new gasket set, and use assembly lube or u wont like the outcome. Other than that u should be pretty good, good luck and double chack specs and use proper torque specs
Old Jan 3, 2012 | 07:37 PM
Leafydialupking's Avatar
Turbo or SC? For SC that comp is super duper low, for a turbo thats the kind of comp you would aim for when trying to push the over 40psi area shooting for the over 600 wheel area. Either way its going to be a complete bitch when you're not in boost and your gas mileage will suffer.
Old Jan 3, 2012 | 08:43 PM
It's a 50mm t3/t4 going for 400whp
Old Jan 3, 2012 | 08:59 PM
I think you'd like it better with 9.5:1 pistons, especially since you are going with e.
Old Jan 3, 2012 | 10:05 PM
I'll look into it
06_cobalt's Avatar
Timing chain tensioner and valve springs (for extra insurance).
Old Jan 3, 2012 | 10:08 PM
1LowLS's Avatar
valve springs faux sho.ours seem to float valves past ~13 psi.
Old Jan 3, 2012 | 10:17 PM
Lol? all stock eco valves are the same, and 14psi at 7k rpm with no valve float and how many lnf guys have pushed that tiny turbo to 30+ psi?
Old Jan 4, 2012 | 08:12 PM
BLKLS's Avatar
Port the head
Old Jan 4, 2012 | 08:17 PM
1LowLS's Avatar
I said springs,not valves My buddys 2.2 turbo started floating past 13.Couldnt figure out the misfires it had up top.now that he has zzp springs,he's up to 23ish with no float.not saying they all do this,as mine is at 13 with no float,but some do.better safe than sorry
Old Jan 5, 2012 | 04:12 PM
And I meant to say valve springs because all the valves are in fact not the same.
Old Jan 5, 2012 | 04:56 PM
1LowLS's Avatar
faux sho
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
