Cam ?
Old Aug 26, 2009 | 09:59 PM
  #76
StrongIslandBalter's Avatar
so your pretty much saying the supercharged route would be more reliable,power and cost effective?
Old Aug 26, 2009 | 10:44 PM
  #77
Spanky's Monkey's Avatar
i never said **** was reliable.
i did say you will break ****. that's something i and every other tuner and wanna-be has learned. **** with your car and something can and will break. and it's always when you don't want or need **** breaking but the desire for more power is an addiction. just my 2cent, personal experience and the fact that i've witnessed many a broken heart and empty wallet.
Old Aug 26, 2009 | 11:46 PM
  #78
well my goal is 200whp. I understand what your saying...I just want to know whats the most reliable route to go supercharge or full bolt on,cams. Iam guessing also the sc route is more cost effective?
Old Aug 27, 2009 | 12:18 AM
  #79
NWAE Cobalt's Avatar
heck ya lolol, im about to pull apart my engine :P
Old Aug 27, 2009 | 12:27 AM
  #80
are you really why?
Old Aug 27, 2009 | 06:48 PM
  #81
06Pursuit's Avatar
this thread went way off topic in a hurry. I too am thinking of going the cammed route. Im just not sure of going stg 1 or 2. I use my car as a DD and don't have a back up, so im leaning towards the stg 1
Old Aug 27, 2009 | 06:54 PM
  #82
probly a good lean lol
Old Aug 27, 2009 | 11:47 PM
  #83
my cars a dd and i want some fun. so its either the cams or sc. its so confusing and hard to choose
Old Aug 28, 2009 | 12:05 AM
  #84
cam is easier to install, and you can build on it with bolt ons, sc is more expensive to do so cause your verging on max hp for stock internals
Old Aug 28, 2009 | 12:43 AM
  #85
yeah but i feel like its all end to a means like waht happens when you get your intake,tb,header,dp,cat back,pulley,cams,manifold,tune. after that what else is their besides porting and polishing. supercharge your throwing it on and then you can add stage kits, even run meth.
Old Aug 28, 2009 | 12:55 AM
  #86
06_ion2's Avatar
ueaj
Old Aug 28, 2009 | 12:56 AM
  #87
you can do adjustable cam gears, higher compression ratio, stroke it, bore it, n2o, lots of things to do
Old Aug 28, 2009 | 01:18 PM
  #88
what do you mean stroke it? and whats uaje ion?
Old Aug 28, 2009 | 01:35 PM
  #89
stroking is to change the amount that the piston moves to gain hp, usually you do this by using a diff length rod
Old Aug 29, 2009 | 01:37 AM
  #90
you know what would be a great project somebody dropping a v8 in a cobalt wonder if its anywhere near possible. I know ill be having wet dreams tonight )
Old Aug 29, 2009 | 10:00 AM
  #91
06Pursuit's Avatar
its been done, an LS1 swap, not cheap though
Old Aug 29, 2009 | 10:42 AM
  #92
go look up victory red ss....he has been working on it for a while now, but he has had alot of diff problems with shops and stuff... long story but worth it
he has his own website about it to...lets see if it lets me post it
victory-red-ss.ca
Old Aug 29, 2009 | 11:29 AM
  #93
guess you cant have an ls1 and fwd lol wonder what other engines are swappable
Old Aug 29, 2009 | 12:39 PM
  #94
no lol, he is going lsx i believe and rwd conversion
has been in the process for QUITE a while, he has a DD cobalt too hahaha
Old Aug 29, 2009 | 06:04 PM
  #95
okay nighthawk ? where your at lets say your running 93 octane. does that fgive you any hp what so ever and the other ? is if you use octane boost what does that do?
Old Aug 29, 2009 | 06:13 PM
  #96
im running 92, no 93 around here lol
and i guess i dont understand the second ? but for the octane boost, its supposed to raise the octain of pump gas, i just use race gas if i wanted that that i can buy local
Old Aug 29, 2009 | 11:29 PM
  #97
okay well why did u go 92 instead of 91 or 92. and waht i mean is why change the octane,and what gains do you get from using octane boost?
Old Aug 30, 2009 | 02:47 AM
  #98
octane allows for more timing and grabs a couple extra ponies
Old Aug 30, 2009 | 04:45 AM
  #99
BlackCobalt707's Avatar
if i understand correctly as well, using high octane fuel in a regular unmodded car will do nothin right? and i think someone told me it can be harmful to the engine, correct?
Old Aug 30, 2009 | 10:57 AM
  #100
in an unmodded car it's gonna burn a little cleaner. won't do **** for power though but I run 93 in my 05 Vue Redline v-tek powered 3.5l anyway. the higher octane full also you to advance spark ignition in order to creat more power. with the right mods you can get a lot outta your little 2.2l.
