Can 2.2s take more than 10 psi 's
Old May 24, 2009 | 01:16 AM
El Mariachi's Avatar
I heard they can only take up to 10 psi. can they have more compression?
Old May 24, 2009 | 02:24 AM
Sentry's Avatar
Depends on the turbo. A little T25 might be able to pump out 15 psi just fine, and on a bigger turbo, say a GT35, you would only be able to handle 5-7 psi before power becomes too much for the internals.
It's all about CFM not PSI, unless you're talking about the actual intake or manifold.
Old May 24, 2009 | 02:25 AM
HunterKiller89's Avatar
they would break at a certain HP level, not a psi level. i would say it can probably take 320-330bhp, so maybe 275whp, however no one has really ventured up there on a stock bottom end, nor could i say how long they would last at those power levels. the actual psi level will be dependent upon the compressor. I have no idea how much power 10psi would be from your turbo, so i cant really answer the question in terms of psi. I will say this though: your ghost icon is awesome. I need a hunterKiller hydralisk icon
Old May 24, 2009 | 10:02 AM
^^Ya I forgot to add that in there about the compression in the question, i was at work and so tired cause I worked 16 hours last night. Also I just purchased my new rods and pistons with an 891 ratio so I can push more.
Hell Ya! Ghost is the most bad ass unit there is! lol NUKES man
I know Im jacking my own thread but hows the car situation?
now back to our featured present question...........
Old May 24, 2009 | 10:07 AM
Turbo06Sedan's Avatar
i'd worry about your intake mani
Old May 24, 2009 | 10:10 AM
they say its good up to like 350 hp i think, but I have to look in the book again, I could be wrong, it probibly can take more than that
Old May 24, 2009 | 10:13 AM
blackbolt89's Avatar
yeah, what kind of intake mani do you have? i'm hoping 2.4 cause the stock 2.2 ones like to go boom with higher pressure.
Old May 24, 2009 | 10:17 AM
PRND3L's Avatar
i know you are asking a turbo question, but 07cobaltguy is running the S/C setup on his 2.2 and has stage 2 pulley on it, has to be running at or close to 15psi
Old May 24, 2009 | 10:57 AM
07cobaltguy's Avatar
i ran 12 pounds on my GT28
and i ran 16 PSI on the supercharger
Old May 24, 2009 | 03:43 PM
Jn2's Avatar
Jn2
I'm going to run 15psi on my m62, as far as how much psi ur engine can take no one knows, yes to much pressure is a problem, air enters the engine already compressed, than it's compressed more, to much initial compression could **** the pistons up
Old May 24, 2009 | 03:50 PM
guys, psi from a M62 and PSI from a turbo are NOT comparable.
Its all about the hydralisks tho dude.. ghosts are badass, but mass hydras own all.
as fr the car...the car is fine, the ticket situation is looking ok, but very expensive (im almost $3k in the hole for attorney expenses), but it wasnt impounded or anything so i can still drive around.
I would upgrade to the 2.4 manifold tho. flows better and is stronger, and its only like a hundred bucks? maybe two hundred
Old May 24, 2009 | 04:04 PM
I hate when zerg masses up lol im a terran guy, thats why you use science vessels and bug spray them lol works very well.....oh man now i need to play starcraft again lol
Thats good, next time this all happens again have your dad say "I didn't know he took the car out" and end of story no one get completely screwed.
I just wanted to know if the engine would handle more pressure with new pistons thicker gasket sets
Old May 24, 2009 | 04:06 PM
Im not in reference to the hp it can support, but more so the pressure.
right around 15psi, its going to debate on blowing or not. You might get lucky and even push up beyond that.
the 2.2 plastic intake mani is 2 pieces. the 2.4 is a solid piece. In theory, the solid should with hold more pressure, since theres no fault line so to speak.
Good luck though!
Old May 24, 2009 | 04:08 PM
Good luck though!
didnt know the 2.4 mani was a one piece. hhhhmmmm
Old May 24, 2009 | 04:09 PM
How so?
psi is..psi.
10 psi from a turbo, is the same amount of pressure from 10psi from a supercharger.
The only difference is air flow.
But PRESSURE is the same.
If you are saying 1psi of a turbo makes (ex.) 10hp per psi. and 1psi from the supercharger makes say (ex.) 5hp per psi. Your right in the aspect that psi doesnt mean the same hp between the 2.
10psi from a HUGE turbo wont make the same power as 10psi from a baby turbo.
However, pressure wise its all the same.
Old May 24, 2009 | 04:27 PM
How so?
psi is..psi.
you're correct. pressure wise, its all the same. but it isnt pressure that blows the stock pistons/rods, its power, and the OP was effectively asking how much power the stock bottom end can take
BTW, burrow > irradiate
mass hydras and lings with a little strike force of 12 guardians and 12 mutas and im set to rape anyone
Old May 24, 2009 | 05:49 PM
pacific cobalt's Avatar
You have the same hahn kit as me and I've been running mine at 14 psi.
Last week I turned it down to 13 psi.
Interceptor gauge shows 242 Net hp @ 6350 rpm's
There was a person here who ran the GT2860RS on his 2.2 at it's max. of 25 psi with forged internals using the canned SCT tune that comes with the Garrett Alpha Kit.
Was that you or do you know who this person was?
Old May 24, 2009 | 06:02 PM
CobaltLs_14's Avatar
all you guys that are running at 10 psi plus what kind of power you putting down?
Old May 24, 2009 | 06:04 PM
IonNinja's Avatar
who the hell did or would do that? I highly doubt that tune would provide the fuel needed at those power levels...what injectors come with that kit anyway? Probably would run out of injector too if they're only 32#ers
Old May 24, 2009 | 06:20 PM
The kit comes with 39#
I tried to search for the thread where he posted about this but I can't find it
Old May 24, 2009 | 06:42 PM
tru2nrtt777's Avatar
I would bet more on the rods and rings. Piston will hole decently... even if it is a puny little thing.
Old May 24, 2009 | 07:31 PM
agreed. rods break first under power, and the rings are so shitty they'll probably go soon after
Old May 24, 2009 | 08:16 PM
mrsilent13's Avatar
dawg why didnt you ask me this question....
as soon as i change out my intake manifold im going to bump the boost up to 18-24psi
Last edited by mrsilent13; May 24, 2009 at 08:16 PM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 27, 2015 08:53 PM
