car has problem starting dealership didn't do anything
Old Jul 27, 2008 | 10:58 AM
TPRMcfly's Avatar
i took my car to the dealership saturday to get it looked at. Sometimes it doesn't want to start, it turns over then just dies. and it was there for about 3hrs and they couldn't replicate the problem so i have to wait untill something breaks, or i get stuck somewhere i'm thinking its just the starter but anyone else think it might be something else?
Old Jul 27, 2008 | 11:01 AM
Whitty's Avatar
now that you mention it. A few times this last week my car turns over a few times then stops. then turn the key and it works. is that what you mean? so far i haven't thought anything of it cuz im still used to the **** car i used to have before this. lol
Old Jul 27, 2008 | 11:02 AM
TPRMcfly's Avatar
yeah just like that but when i goto start it agian it takes a few seconds to kick over then runs great
Old Jul 27, 2008 | 12:02 PM
Whitty's Avatar
yah i have that too just not very frequently. This i think has happened 3 times in 2 months or so (estimate. its happened 3 times just dont remember the first. )
Old Jul 27, 2008 | 12:04 PM
TPRMcfly's Avatar
its prob 2-3 times a week for me
originaladrian's Avatar
check all ur grounds, i had a loose ground a while ago and it had kindof similar symptoms.
Old Jul 27, 2008 | 12:22 PM
TPRMcfly's Avatar
ok ill go out and check in a bit thanks
Old Jul 27, 2008 | 12:24 PM
Jackalope's Avatar
The starter ONLY spins the engine over, if its doing that then it is NOT NOT NOT the starter! Sounds more like a sensor issue to me. Now be it the mass air or the TPS that I can't say. But if she's spinning your starters good.
Old Jul 27, 2008 | 12:25 PM
Codyak Supercharged's Avatar
i noticed it happens more frequently if i dont let the fuel pump prime completely. So letting the gas guage go to full then see if it keeps happening.
Old Jul 27, 2008 | 12:42 PM
TPRMcfly's Avatar
ok i'll try that and see if it work
yeah the starter does sound like its working just the engine isnt turning over
Old Jul 27, 2008 | 12:44 PM
Halfcent's Avatar
I'm old school
If the engine turns when you turn the key, then your starter is fine. It doesn't matter if the engine actually starts or not.
...Damn, somebody beat me to it.
Old Jul 27, 2008 | 12:59 PM
nuttzzy's Avatar
Accualy mines been doing it every time for a few days. I start it it jumps up to 2000 rpms when it fires then acts like its ganna idel down but just keeps dropping till bout 250rpm's then gose right back up to 1500 rpms or so then dose the same thing only it dies instead of recovering at 250 rpms. sometimes it doesnt recover it dies the first time. its throwing a code refering to the purge selinod valve.
Old Jul 27, 2008 | 05:10 PM
MP81's Avatar
Vacuum leak, possibly.
Or a fuel pump, if it takes a long time to fire.
My Camaro lost a fuel pump, it would take 2 minutes of solid cranking to even get the car to barely sputter to life - oh, and my foot was too the floor, on the gas.
Old Jul 27, 2008 | 05:12 PM
nuttzzy's Avatar
im thinking vacuum leak but i dunno where to check on mine.
Old Jul 27, 2008 | 07:53 PM
MP81's Avatar
Any vacuum line...
There should be a diagram of the line routing somewhere...
Old Jul 27, 2008 | 09:53 PM
TPRMcfly's Avatar
Originally Posted by MP81
Any vacuum line...
ok i'll try to find that and look thanks
Old Jul 27, 2008 | 10:28 PM
Red07SSNA's Avatar
Turn your key on and you can hear the fuel pump run for about 2 seconds. Let the pump run and turn off before trying to start the engine. If that works, ask the dealer to look at your fuel system for leak down. Also Check for DTCs with a scan tool to see if your car is diagnosing a problem.
vjoel2011
Oct 2, 2015 12:11 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
NoBalt123
Sep 4, 2015 07:10 AM
