cel after fujita cai install
I installed the Fujita cai on my 2.2 l61. After the installed within 10 miles the cel came on. p0171 lean mixture fault. I checked for proper install of maf sensor which was good. no vacuum leaks. I had no problems before the install, so I know that this is causing it. Is this common of fujita cai? or cai in general. Does this just require ecu tuning? Thanks
i know anything above 14.7 a/f ratio will cause overheating. does anyone have any ideas to eliminate this problem. Does other cai cause this same problem, or is it just the fujita?
I had the same issue with my Weapon R (which is terrible quality btw). As soon as it was on, I got the lean code, and the car was idling at 1300-1800 rpm constantly. I had it taken in to a tech shop. They made me replace the stock system. No change. they cleared the codes, and oddly enough it ran like a dream. Still won't drop rpm's when I'm shifting half the time, but that's another set of codes, and most likely a computer error or vaccum leak somewhere. i think?
What does this do? I have a fujita on mine too. all was good for 8 months or so after I installed it but now i have a cel on too. Pretty sure its the same code as above and people said the gas cap wasn't replaced right after refueling? (three clicks) but i always make sure it clicks at least three time and the code still hasn't gone away after unplugging the battery too.
Heyy that's what members on here suggeted lol but I did the battery thing and still got a cel. It cleared it but came back on. So I did some hunting and took the headlight and bracket out to find a dirty dirty air filer. So I put the stock air cleaner back on yesterday ans no more cel so far. When I get a new filter the Fujiyama will probably go back on though.
I just got my Trifecta tune, put the Weapon-R on a couple hours later, and the cel came on. I'll get it pulled tomorrow, then have it cleared when I datalog again. I guess that's a good thing if I'm flowing that much air.
