Clutch Pedal Stuck Down... Help..
Old May 3, 2013 | 04:09 PM
pykie's Avatar
Well after all the issues I'm starting to have lately I think my car doesn't wanna be driven this summer.
I got the motr back in everything done, go to bleed the clutch and now my clutch pedal is stuck to the floor, u can't put it back out.
I had the clutch rod brake before and the pedal just flopped around but this time the pedal is stuck to the floor.
Someone help please
Thanks.
Old May 5, 2013 | 08:42 AM
BankerBalt's Avatar
Did you replace your slave cylinder? Cuz thst could be your issue
Old May 5, 2013 | 09:29 PM
pykie's Avatar
I had to replace the little black plastic thing that runs into the tranny that u bleed because my stock one was seized and it broke, other then that only thing that's been replaced is the Spec Stage 3+ Full ring clutch and presure plte and a throw out bearing.
Old May 27, 2013 | 10:22 AM
pykie's Avatar
No body knows what would cause this? I don't wanna remove the tranny if I don't have to.
Old Jun 9, 2013 | 11:13 PM
pykie's Avatar
L looking for tips back to work now so want it done now
Anyone?
Old Jul 4, 2013 | 07:13 PM
scotty_95's Avatar
our chevy truck at work, the clutch pedel stuck on it and it turned out to be the pin that holds the pedel to its bracket, on the truck it was a crappy plastic pin that wore out and got wedged, hard to explain but might just check out the pedal its self good,
Old Jul 10, 2013 | 10:17 PM
scotty_95's Avatar
figure it out yet?
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
