clutch slippage 2.2 SC
so the stock 2.2 clutch doesnt want to handle boost very well, every now and then it slips. Could i go with a stock LSJ clutch and fix this problem? im running the m62 w/ 60#, 2.8", CAI, zzp s3 heat exchanger.. is this all i need for a cheap fix?
http://cgi.ebay.com/ebaymotors/Chevy...item35aa6eb8e1
i've heard great things about the exedy stg 2 but beware it's a leg worker.. that being said i have a spec stg 3 .. i got it for dirt cheap though.. if i didnt i would've went with the exedy you can get them on ebay for like 300 or so..
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
thanks guys! ill take a look at what I can find around.. i dont need it right away but every once in awhile it slips so i know ill need one eventually.. thanks again
that sucks, mine lasted a 6 months normal, 6 more months slipping in the high end, and than i went with a excedy stgII, which i highly recommend, it hold great, i re-used the sock flywheel, just had it machined
