clutch slippage 2.2 SC
Old Jun 29, 2010 | 04:31 PM
wbrevels's Avatar
so the stock 2.2 clutch doesnt want to handle boost very well, every now and then it slips. Could i go with a stock LSJ clutch and fix this problem? im running the m62 w/ 60#, 2.8", CAI, zzp s3 heat exchanger.. is this all i need for a cheap fix?
http://cgi.ebay.com/ebaymotors/Chevy...item35aa6eb8e1
Old Jun 29, 2010 | 04:37 PM
Brags's Avatar
Nope they are different trannies. Need one specific for 2.2.
Old Jun 29, 2010 | 04:40 PM
jbenso4's Avatar
best off getting a stage two excedy
http://www.turbotechracing.com/produ...dcategory=5615
Old Jun 29, 2010 | 04:47 PM
ei3dag3's Avatar
go with a spec stage 2 + for the 2.2 and never look back.
stock flywheel works too.
Old Jun 29, 2010 | 05:36 PM
elecblue06's Avatar
i've heard great things about the exedy stg 2 but beware it's a leg worker.. that being said i have a spec stg 3 .. i got it for dirt cheap though.. if i didnt i would've went with the exedy you can get them on ebay for like 300 or so..
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
Old Jun 29, 2010 | 07:30 PM
cobalt2007ls's Avatar
I have the same setup with a few other things and i went with the exedy stage 2 with a new gm flywheel and throw out bearing and it holds very well.
Old Jun 29, 2010 | 11:32 PM
wbrevels's Avatar
thanks guys! ill take a look at what I can find around.. i dont need it right away but every once in awhile it slips so i know ill need one eventually.. thanks again
Old Jun 29, 2010 | 11:34 PM
glen229's Avatar
this statment is very true, its a tough clutch , it release's AT THE FLOOR at first, get the zzp clutch rod also
Old Jul 1, 2010 | 02:32 PM
jbenso4's Avatar
haw long did it take u for urs to start slipping?
Old Jul 1, 2010 | 03:34 PM
I didnt even launch but my first pass down+ stock clutch= no more clutch.
Old Jul 4, 2010 | 04:04 AM
Jn2's Avatar
Jn2
you need to bleed your system again, took me 3-4 bleeds to get it to stop engaging off the floor...
that sucks, mine lasted a 6 months normal, 6 more months slipping in the high end, and than i went with a excedy stgII, which i highly recommend, it hold great, i re-used the sock flywheel, just had it machined
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
