coolant temperature
coolant temperature
i was just woundering whats ur guys average coolant temperature. my digit coolant temperature is usually around 90-100 degreee celis after driving for 30 mins is that average.
Mine sits at 194*F
Just curious, but how does a tune lower your coolant temp other than having the fans turn on earlier? Even with my fans on earlier, I still need a 160 stat in to make the gauge lower.
90 Celcius is right around 190 Farenheit......these cars most likely have a 190 thermostat, so that's the normal operating temp.
I always thought the fans started at 100.
Last edited by maverick0716; May 27, 2008 at 01:44 AM. Reason: Automerged Doublepost
yeah see I live in america...and so I use the Fahrenheit system....no no jk jk..........I like fahrenheit because its a little more detailed than celcius....but yeah I usually ran 189 or 192 stock on the freeway here and up to 219 on the streets till the fan kicks on and lowers it back to 192....my cooling mods have dropped it down to about 180-185 on the freeway though.....although thermostat is kicking in and out of working right now on the dash display...figure I might get a 160 should it really go **** up....
Usually 86*C. You should be fine on a long drive as air will constantly be rushing through the grill opening. But just for peice of mind check the coolant with a hydrometer, and that will tell you how good the coolant is.
230 is starting into the danger range....Travis...you may want to do some cooling mods to that car or you will be paying for it later....i run mine all the time yet my car will not go over 190F....never have i seen it once go over that...it's all on how you take care of the car and how you drive it....the harder you drive (and i drive mine pretty hard...the more heat it has....the more care you give it, all the more it gives back....
Pretty neat I think
