diferences between 07 and 08 engine
The camshaft position (CMP) actuator system is an electro-hydraulic operated device used for a variety of engine performance and operational enhancements. These enhancements include lower emission output through exhaust gas dilution of the intake charge in the combustion chamber, a broader engine torque range, and improved fuel economy. The CMP actuator system accomplishes this by changing the angle or timing of the camshaft relative to the crankshaft position. The CMP actuator simply allows earlier or later intake and exhaust valve opening during the four stroke engine cycle. The CMP actuator cannot vary the duration of valve opening, or the valve lift.
nice man. Cheap is the key. Cause my older sister gave me my kicker L5 and Rockford Fosgate amp, little did I know the deck, XM module, wiring harness, 2 amp kits, Sony Xplode amp for Highs, all would still cost me like 800 bucks. Christ if i knew it would come to all that i would have just got rims and wore headphones.
patooyee
Oct 1, 2015 01:07 PM
