Downpipe 02 Sensor question, please help!
I purchased the ZZP stainless downpipe with cat for my 07 Cobalt 2.2l. I noticed there are two 02 bungs (front and rear 02 sensors) on the stock downpipe and only one on the downpipe I purchased from ZZP. Do the two 02 sensers connect somehow or do I not use one of them at all? If so, which do I use? Will it throw a code? Please provide as much info as possible on the subject. Thank you!
I have a ZZP header/dp... Threw a code as soon as I unplugged the o2 and connected my wideband.
Can't remember what I did with the other o2 though.. lol ****..
OP.. Do you have a c5z06? ANd a cobalt as a DD?
OP- Most aftermarket header's / DP's come with an O2 bung on each of them. On your particular year they put both sensors on the DP. On 05/06 there is one on the manifold and one on the DP.
So you have 2 choices. Get an aftermarket header , or have another O2 bung welded in your new DP
read it again...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
