dowpipe question
Old Aug 16, 2009 | 01:02 AM
HolyJerex212's Avatar
dowpipe question
hey guys i got a question...my cars got the two cat dowpipe on my car...does anyone know if the ss downpipe will swap just fine and im sure im going to need a tune since the cat systems must be different? i just need some help with this guys...thanks in advance
ps if im doing a tune im doing a 2.4 throttle body and an ss header and downpipe.
Old Aug 17, 2009 | 01:03 AM
anyone ? bump
Old Aug 17, 2009 | 01:11 AM
whats the bolt pattern on the LS? for the downpipe
i took my SS downpipe off and its a triangle bolt lay out
it has a huge ass cat and idk how your header out let looks for matching up
hope this kind of helps haha
Old Aug 17, 2009 | 01:16 AM
yeah its the same pattern tri bolt up top near manifold and two bolt near catback
Old Aug 17, 2009 | 01:29 AM
yee thats it, if u do this make sure the top of the downpipe matchs up like pipe size and gasket and all match up. i blew a gasket on my aftermarket downpipe and the stock gasket was too big haha, but i got a better gasket problem solved haha
u should be able to bolt up no problem just check the specs and stuff
Old Aug 17, 2009 | 01:54 AM
even tho theres two cats on my downpipe and only one on the new one i shouldnt have a problem?
Old Aug 17, 2009 | 02:47 AM
two cats? damn haha it should be fine it wont be as restrictive cuz the cat helps keep noise down haha thats why catless cars are freaking beast.
i have a 2.0l supercharged cobalt and im not familiar with the 2.2l motor but it should be similar as u will just be running a single cat and have better air flow
heres a pic of my vibrant downpipe and the lsj (stock) downpipe
Old Aug 17, 2009 | 01:48 PM
2007victoryred's Avatar
You shouldnt need a tune. Just find a dp from an ss that is the same year as yours and there should be no issues. Everything should just bolt up just fine.
I just noticed your an 06 I would try and get a ss mani also.
Last edited by 2007victoryred; Aug 17, 2009 at 01:48 PM. Reason: Automerged Doublepost
Old Aug 17, 2009 | 02:28 PM
Whitty's Avatar
no tune needed year doesn't even matter they all bolt up just fine
Old Aug 17, 2009 | 02:31 PM
1badBlueberrySC's Avatar
The LSJ downpipe will bolt right up yes... as will any aftermarket for the S/C motor.... now the LNF no!
Old Aug 17, 2009 | 03:42 PM
The only reason the year matters is o2 sensor locations. If he does a mani and a dp it doesnt matter but if he only does a dp he should find one off an 06 so everything matches up.
Old Aug 17, 2009 | 11:19 PM
Brags's Avatar
I dont know about other years but my 07 has both sensors in the downpipe. I had to get a lsj exhaust manifold to match because the lsj dp has one bung for sensor.
Old Aug 17, 2009 | 11:25 PM
Red07SSNA's Avatar
This is correct...look into the positions of your O2 sensors! Also get a DP for the type tranny you have...auto tranny equipped Cobalts DPs are longer than the manual tranny equipped Cobalt DPs. If you want to insert a DP from a manual car into an auto car you'll have to do some fabrication.
This is on the 2.4L Cobalt...the 2.2 has the same issue:
https://www.cobaltss.net/forums/show...&highlight=LSJ
Old Aug 18, 2009 | 01:01 AM
the downpipe im gettin is from an ion redline i assumed that essentially an ss downpipe...and i already checked i have one o2 on my mani and the other on my dp
Old Aug 18, 2009 | 02:54 AM
look at all the help now Holyjerex haha good luck with the install
Old Aug 18, 2009 | 10:19 AM
Red07SSNA's Avatar
Since you have a manual you'll be good to go...
Old Aug 18, 2009 | 06:21 PM
lol yeah man glad you guys are around for all this technical bs..wish these 2.2s were more simple to mod like my LT1 i can find thousands of parts from old small block chevys that work its great
Old Aug 21, 2009 | 02:36 PM
zack93's Avatar
can u use the stock lsj exhaust of a redline or is it routed different under the car?
Old Aug 24, 2009 | 01:21 AM
blackbolt89's Avatar
ive got a 06 SS dp if your other deal falls through.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
