f23 tranny question
Old Jan 14, 2010 | 01:53 PM
kxrida2000's Avatar
f23 tranny question
I am looking to do a turbo build and have the parts to be over 400 hp. I have a new clutch and flywheel but my tranny is stock. Will the tranny hold up or is there anything i can do to make it stronger and hold up. any info will help due to me not knowing a while lot about 5 speed trannys.
Old Jan 14, 2010 | 03:34 PM
06_ion2's Avatar
get a lsd and cryo the trani is pretty much all you can do.. Dont jam through the gears or it will blow up before you know it.
Old Jan 14, 2010 | 04:33 PM
stenguyen1's Avatar
Wat is cryo? do you mean build the synrods?
Old Jan 14, 2010 | 05:05 PM
06_ion2's Avatar
Heat treated so the gears are stronger.
Old Jan 14, 2010 | 05:12 PM
stacy_dammit's Avatar
Wah? Im st00pid. Can explain a little bit more, and how would you go about getting this done.
Old Jan 14, 2010 | 05:56 PM
06_ion2's Avatar
http://www.diversifiedcryogenics.com/motorsports.html
Old Jan 14, 2010 | 06:22 PM
Jn2's Avatar
Jn2
fstcavy is pushing more than 400hp on his cavy and he's on a stock tranny w/a LSD in it, running Ga axles
Old Jan 14, 2010 | 06:23 PM
Hmmm interesting. Probably cost a pretty penny to do that. I imagine you'd have to take the whole tranny to them. But it would be worth it since it would make it last 3x longer by doing this process.
Old Jan 14, 2010 | 10:21 PM
06_ion2's Avatar
well see how long a open diff f23 lasts for this summer.
Old Jan 14, 2010 | 11:39 PM
ryansalazan's Avatar
you dont think a little less than 300whp would effect the tranny stock do you? or does a lsd really help that much
Old Jan 15, 2010 | 11:16 PM
Maven's Avatar
the LSD is just gonna help keep you from doing big nasty one wheel spins and destroying your final drive.
An F23 can handle 300hp no problem.
Old Jan 16, 2010 | 02:47 AM
alrighty then thanks maven thats all i needed to know. ill look into a lsd then
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
