Failed test on Mode $06 report Help!!?
Old Mar 29, 2014 | 05:25 PM
Richie353's Avatar
Below is a test I ran with the torque app after I recently got an OBD II adapter. Worry a lot when it comes to my balt and there are a bunch of categories with 'Fail'. anyone know how to read this stuff? (P.S. Yes I know, noob, here.) Fails underlined for convenience
Mode $06 report generated by Torque for Android
Vehicle VIN: 1G1AJ55F967787177
Vehicle Manufacturer: Chevrolet
Vehicle Calibration ID: 126
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0.31915V Min: 0.31915V
Test result value: 0.31915V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.45018V Min: 0.45018V
Test result value: 0.45018V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.65026V Min: 0.65026V
Test result value: 0.65026V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 94ms Min: 0ms
Test result value: 13ms
PASS
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 125ms Min: 0ms
Test result value: 15ms
PASS
MID:$01 TID:$15
Max: 41,190 Min: 4,144
Test result value: 5,376
PASS
MID:$01 TID:$80
Max: 65,535Changes Min: 35Changes
Test result value: 245Changes
PASS
MID:$01 TID:$81
Test result value: 246Changes
PASS
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 950Count Min: 0Count
Test result value: 213Count
PASS
MID:$02 TID:$8b
Max: 1.10068V Min: 0.7004V
Test result value: 0.98735V
PASS
MID:$02 TID:$8c
Max: 0.30012V Min: 0V
Test result value: 0.25095V
PASS
MID:$21 TID:$4d
- Catalyst Monitor Bank 1
Max: 0mHz Min: 4,177mHz
Test result value: 19,744mHz
FAIL
MID:$21 TID:$a0
Max: 250ms Min: -25,000ms
Test result value: -14,991ms
PASS
MID:$30 TID:$9e
Max: 62.85594% Min: 6.32374%
Test result value: 61.79689%
PASS
MID:$30 TID:$b7
Test result value: 71.56329%
FAIL
MID:$3a TID:$c0
- EVAP Monitor (cap off)
Max: 12L Min: 0L
Test result value: 0.904L
PASS
MID:$3a TID:$c1
Test incomplete or dependant test failed
MID:$3c TID:$c8
- EVAP Monitor (0.040")
Max: 0.6289Ratio Min: 0Ratio
Test result value: 0.12109Ratio
PASS
MID:$3c TID:$c9
Max: 0.72655Ratio Min: 0Ratio
Test result value: 0.10156Ratio
PASS
MID:$3c TID:$ca
Max: 1Count Min: 0Count
Test result value: 0Count
PASS
MID:$3c TID:$cb
PASS
MID:$3d TID:$c4
- EVAP Monitor (0.020")
Max: 6,553.5S Min: 60S
Test result value: 60S
PASS
MID:$3d TID:$c5
Max: 2,500Pa Min: -8,000Pa
Test result value: 141.5Pa
PASS
MID:$3d TID:$c6
Max: 15S Min: 0S
Test result value: 0.3S
PASS
MID:$3d TID:$c7
Max: 40L Min: 6L
Test result value: 6L
PASS
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 45Count Min: 0Count
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$50 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Heater Monitor Bank 4 - Sensor 4
Max: 45,071 Min: 6,162
Test result value: 65,520
FAIL
MID:$68 TID:$30
Max: 409.60001 Min: 5,641.7002
Test result value: 2,893.1001
FAIL
MID:$70 TID:$a2
Test result value: 41,584
FAIL
MID:$70 TID:$b2
Test result value: 45,680
FAIL
MID:$70 TID:$fc
Test result value: 64,624
FAIL
MID:$90 TID:$c0
Max: -24,346ms Min: 4,144ms
Test result value: -16,240ms
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 1Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 4Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 3Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
Test result value: 15Count
PASS
MID:$b0 TID:$a2
Max: -74.30399% Min: 12.64749%
Test result value: -72.90617%
FAIL
MID:$b0 TID:$cf
Test result value: -37.74714%
FAIL
MID:$d1 TID:$66
Max: 41,088 Min: 10,432
Test result value: 13,280
PASS
MID:$f0 TID:$af
Manufacturer defined MID -
Test result value: 45,040
FAIL
MID:$f0 TID:$df
Test result value: 57,328
FAIL
End of report.
Old Apr 2, 2014 | 05:49 PM
scagnetti76's Avatar
I don't know how to read hex code, but most of the failed tests dont have a definition, and some dont make any sense. o2 sensor bank 4 sensor 4 doesn't exist. Your 02 voltages look good and passed, misfires passed etc. I wouldnt worry about the failed ones if you have no check engine light. Probably unused code. I dont work in an emissions state though, maybe someone with more experience with emissions testing will chime in.
Old Apr 4, 2014 | 01:57 PM
Richie353's Avatar
Thanks for the incite. You're probably spot on that I shouldn't be too worried.
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Oct 1, 2015 08:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
