fIANL .4 MANI QUESTION BEFORE INSTALL!!!!
Old Mar 17, 2012 | 09:28 PM
David6312008's Avatar
I have a newer 08+ 2.4 mani
going on an 08 with L61 motor
will I need the adapter plate?
Bought it from a member with an 09 G5 LAP motor and he didnt need an adapter, however two different motors and not sure how much difference there is besides slight power and fuel econ...
Final question I promise I just want every fact I can get before ripping into the upgrade.
Old Mar 17, 2012 | 09:36 PM
AzraelRaezier's Avatar
if you plan on running the 2.2 TB on the IM i believe you need the adapter plate.
Old Mar 17, 2012 | 09:44 PM
drumrush's Avatar
I ran that setup on my car without an adapter plate
Old Mar 17, 2012 | 09:46 PM
May I ask how long? lol
What you think of the mani upgrade overall?
Old Mar 17, 2012 | 10:44 PM
Jesse's Avatar
I will save you from the, "Use the search button." No. Your 2008 uses a 6-pin throttle body. It is different from the earlier 8-pin ones. It doesnt matter if the motors are different. Only if the throttle bodies are. The early throttle bodies do not look like they will seal to theanifold at all. They aren't smooth on the back. 6-pin ones are, in theory, and will seal. Also, if you are worried about the bolt pattern go look at the upper left corner of the tb on your car now. There are two holes. One has a bolt through it and the other is where you would bolt it on the 2.4 mani.
If anything just try it. I will have this adapter if you decide you want it. I won't drive to Waco but I can mail it to you if you are that worried.
Old Mar 17, 2012 | 10:49 PM
Thanks I just cant afford my car being down since its my DD but I will check it out
Old Mar 17, 2012 | 10:56 PM
Jesse's Avatar
Look at pics on google. Look for 2006 and 2010 throttle bodies. Look at how different they are on back. I will be installing my 2.4 manifold Tuesday. I have the exact same motor as you. I will let you know and will take pics.
Old Mar 17, 2012 | 11:05 PM
I jst looked at the 2.4 mani and my 2.2TB and it looks like all I have to do is move the bolt from the far upper left to the closer one and bam should be a direct fit.
Im thinking about trying this tomorrow since I will be off at 4pm and be off monday and tuesday which gives me plenty of time o get it done or put the stock one back on..just got to pick up 3 ft of 1/2 vacumm hose and a couple of clamps.
Old Mar 17, 2012 | 11:09 PM
Jesse's Avatar
Do it. I have some sealer in case the map sensor isn't a direct snug fit. Otherwise I will be fine.
Old Mar 17, 2012 | 11:23 PM
I will know as soon as I put the TB on the mani so if it doesnt work then all I have to do is put the tb back on and thats like 5 to 10 minutes tops
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Stuff
Oct 1, 2015 05:47 PM
