Final clutch post from me
Alright I just want to ask one final time. I have an 07 cobalt ls with a supercharger setup and been told either the exedy stage 2 or a spec stage 2+. I only want to remove the trans once and do it the right way when its done. please let me know what clutch your running. Thanks. I also have a stock flywheel.
Also if the exedy is the one everybody runs do you get the thick or thin disc?
exedy stg 2 is a great clutch it'll have very stiff engagement though fyi.. i'd look at getting the zzp adjustable clutch rod as well as resurfacing the flywheel / buying a new one.. a new one is like 75 bux from gmpD
I don't have a spec 2, I just have felt it. spec 2 is more than enough. I know the spec 2 works and works well, I don't know about the exedy other than the stg 3 hypersingle
I have the Exedy stage 2 laying around ready to go in. Couldn't tell you if I have the thick or thin version honestly. I also just picked up a new flywheel. For under 100 bucks and having 80,000 miles it's not even worth trying to reuse.
