Fuel??
Old Aug 7, 2007 | 06:03 PM
j27's Avatar
j27
Fuel??
What is the highest octain fuel you can put in a stock 2.2?
Old Aug 7, 2007 | 06:11 PM
jigyflyuk07's Avatar
well you CAN put anything into it, i just stick with 87.
Old Aug 7, 2007 | 06:13 PM
BallsoutBalt's Avatar
This is a vauge question, but...
Daily driving - 93
Racing - 110
Old Aug 7, 2007 | 07:02 PM
Black07LS's Avatar
No benefit to higher octain without tuning for it.
Old Aug 7, 2007 | 07:14 PM
th0ughtless's Avatar
I heard higher octane only slows down a stock 2.2..true?
Old Aug 7, 2007 | 07:17 PM
pimpnwink's Avatar
if you are running anything more than 87 in a 2.2 w/o tuning you are waisting money. And that is that. (unless you want to clean out your engine)
Old Aug 7, 2007 | 11:35 PM
Herndon_High_SS's Avatar
Pointless in a 2.2. No benifits.
Old Aug 7, 2007 | 11:37 PM
j27's Avatar
j27
thanks I was asking because I have sum 20% nitro alcohalmix an some vp racing fuel and wasint sher if it would hert.
Old Aug 8, 2007 | 11:49 AM
pimpnwink's Avatar
i think you should just give that to me lol.
Old Aug 8, 2007 | 12:22 PM
j27's Avatar
j27
Its not much gust 1 track days worth.
Old Aug 8, 2007 | 12:27 PM
NJHK's Avatar
https://www.cobaltss.net/forums/general-cobalt-68/most-common-misconceptions-tuners-have-write-up-68058/
Originally Posted by NJHK
3. Higher Octane means more power
Higher Rated Octane Gasoline alone will NOT gain you power. The octane rating in relation to your engine is all referring the resistance to detonation (knock). Detonation is a uncontrolled explosion in your combustion chamber (not like a normal controlled igniting of fuel).
Higher Octane also has nothing to do with flame speed.
Now being that high octane fuel more resistant to detonation occuring, you can yield power gains by advancing ignition timing or even possibly running at a leaner air to fuel ratio (of course this depends on the application and the condition of the engine or setup you're running).
Old Aug 8, 2007 | 07:08 PM
Spanky's Monkey's Avatar
if you're anything more then regular unleaded it really is a waste of money and time.
Old Aug 8, 2007 | 07:28 PM
Novajoe's Avatar
throw some c16 in it... then watch ur valves roast
Old Aug 8, 2007 | 08:53 PM
Haha. I wonder how much that c16 cost a gallon.
Old Aug 8, 2007 | 09:15 PM
Novajoe's Avatar
it's pretty much leaded gas. I'm not really sure how much it goes for but I'm sure it's expensive. I know 100 octane around me is like $5 a gallon so...
Old Aug 9, 2007 | 12:24 AM
j27's Avatar
j27
my 20% nitro alcohol mix was 20 a gall when i got it
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
