fuel pressure went to $%!&
Old Nov 14, 2010 | 03:13 PM
Spanky's Monkey's Avatar
so my fuel pressure really did go to ****. been working out the kinks of course and i've kept an eye on the fueling in particular. its been at 62psi at idle sense i have been able to monitor it. well yesterday it sat in the driveway all day and hasn' moved for a day before that. so for 2 days she's been chill for the most part casue of emissions. well back to yesterday, i got knew vac line in so i decided it would be best to take care of the hosing so i went to town. i started her up when the job was done and hang out a while listening to her settle down into a purr. the fuel pressure is as usual sitting at 62psi and vac is 21inhg at 198 degrees. it was cold out so i was there for 20min or so at which point i shut it down. I've been checking for codes so half an hour late I go back out and heat the car up to 198 again and nothings wrong. night falls a few hours later and i go out to start the car and see the fuel pressure at 162psi. i'm like what the **** at that point. i started the car and the fuel pressure didn't budge. i shut it down and checked my gauge caliberation which is correct and gave the car the night to settle. come back this morning and it's the same **** stuck at 162psi. i do have an lsj pump on there now and i'll be sorely dissapointed if it has failed but such is life. the fuel filter is new for reference.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
