GHOSTS build thread
Old Oct 30, 2009 | 12:23 AM
  #51
06cobaltindallas's Avatar
here is where i stand on this.
the block is currently with golden eagle getting sleeved with their hd sleeves.
the head is still in san antonio with marty, he ran into a small problem with the supertech seats coming loose once they heat test everything, so he had to order a few more.
the car is now having to switch to a cable driven t.b. for the fast system to work and ill need the msd dis-2 ignition control along with the 2 blaster coil boxes for the ignition set up
o and here is a fun interesting fact that alot of people are probably going to flame me on.
a skunk2 fuek rail for the k20 honda engine works on a ecotec motor.
yup we test fitted it and the holes for the injectors line up correctly. its actually easier to run a return style system using it, which i am doing.
Old Oct 30, 2009 | 09:06 AM
  #52
alanoo's Avatar
Sure you're not putting too much stress on the injectors ?
bore center of the K20 is 94mm, and 95.8mm on the ecotec, so the injectors center should be almost the same
should line up "correctly", but not perfectly
Btw, any more info about the golden eagle sleeves ? first time I hear about it for our engines ?
Old Oct 30, 2009 | 10:58 PM
  #53
well they dont get into too many specifics on the engine, they actually spell it wrong ECOTEK lol
but they have us listed as a saturn motor because they did alot of work with lisa kubo's ecotec drag car.
Old Nov 23, 2009 | 01:10 PM
  #54
Cobaltsky05's Avatar
rods and pistons still available?
Old Nov 23, 2009 | 01:18 PM
  #55
rods are for sale not pistons
Old Nov 25, 2009 | 11:23 AM
  #56
ok i got some updates on the build. sorry for the delay, ive been slacking
pics of the head work
pics of the golden eagle sleeved block that just came in
Old Nov 25, 2009 | 11:57 AM
  #57
1BADSS/SC's Avatar
Nice. Doing the complete build right away huh?
Old Nov 25, 2009 | 03:19 PM
  #58
its been a work in progress for a little bit over a year now. hopefully i can get it into the car by the summer
Old Nov 25, 2009 | 03:32 PM
  #59
elecblue06's Avatar
good stuff man .. cant wait to see it all done.. turbo is a bit big IMO without a bore or stroke. did yo go with stock CR or 8.9:1 cr for the pistons
Old Nov 26, 2009 | 12:45 AM
  #60
8.9:1 compression
Old Nov 26, 2009 | 07:48 PM
  #61
Preston's Avatar
this thing is gonna be nuts..
makes me want to do a crazy build, instead of just a stock rebuild...
Old Nov 27, 2009 | 12:19 AM
  #62
thanks for the comments
Old Jul 20, 2010 | 09:08 PM
  #63
ok here is a current update
parts:
short block:
wiseco pistons 8.9:1 compression ovr szd
Pauter connecting rods
Clevite rod bearings
Eagle Crankshaft
GM main bearings
OTTP main studs
Golden Eagle Sleeves
ATI crank dampner pulley
Assembled and balanced by Watts Racing engines via T1 Race Development
Head work:
SCE Exhaust Gasket
COmetic Head Gasket
ARP head studs
Level Zero Motorsports Balance Shaft Delete Kit
Bates Oil Pump Gears
ZZP Phenolic Intake Spacer
Supertech 78lb valve springs
Supertech 0.5mm valves
supertech retainers and seats
All ecotec bronze valve guides
GM adjustable cam gears
Comp Cams turbo grind cam shafts (with cam sensor put on)
Head assembled and ported by Marty Ladwig Racing via Jotech Motorsports
Turbo:
Turbo Manifold by Full Race via T1 race development
Tial V60 wastegate
HKS blow off valve
SPearco Intercooler
Garrett GT35R ball bearing turbo T4
Hahn Intake Manifold
Fuel system:
Injector Dynamics 1000cc high impediance injectors via T1 race development
Walbro 255 fuel pump
bosch 044 fuel pump
kn oil filter
transmission:
Exedy light flywheel
hopefully ill be doing some mock ups next week for u guys
Old Jul 21, 2010 | 01:33 AM
  #64
Spanky's Monkey's Avatar
still in the works i see. how far along now?
Old Jul 21, 2010 | 02:01 PM
  #65
well i am waiting on the delete kit to come in, they are shipping out today.
the short block is scheduled to be done by the end of this week, and then we are going to start doing some mock ups. Im having a custom fuel rail made for $250 and i am going to be making block off plates for the electric water pump. Does anybody happen to know the part number or have 2 of those spacers that attach the fuel injector to the cylinder head? some how i am missing 2
Old Jul 21, 2010 | 02:14 PM
  #66
coopercharge's Avatar
Sounds like a good build dont forget about a good set of sleeves the stock sleeves from what I hear cant handle being bored out. Let me know if I may be wrong.
Old Jul 21, 2010 | 04:07 PM
  #67
my block is sleeved
Old Jul 21, 2010 | 04:45 PM
  #68
joshc.'s Avatar
They can be anything past .030 and they became extra weak I have found this out the hard way since my block has been bored twice at .020" your fine after that geats hairy. Sleeved is the best way.
Old Nov 12, 2010 | 01:38 PM
  #69
i know its a couple months bump but what the hell ever happened to this build?!
Old Nov 12, 2010 | 01:49 PM
  #70
sometimes it takes time. i'm back on the road after being down for 7 months. life happens but i too am interested in an update.
Old Nov 12, 2010 | 01:51 PM
  #71
Glowbalt's Avatar
this ****'s gonna fly
Old Nov 15, 2010 | 05:16 PM
  #72
hey somebody actually remebered my build lol
right now i am having my new ignition system and harness made.
im running the M&W pro 14 kit with honda cbr coils ill have pics for u guys next week
oh and im selling my GT35r turbo that has been sitting in the box brand new for 2 yrs
06MetallicBalt
Jul 20, 2025 08:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
riceburner
Oct 2, 2015 05:47 PM
