GM Performance Intake System
you have nothing to worry about with a warrenty. Unless if you get an Injen intake and it causes the problem needed for warrenty, they cant say **** & they gotta fix it.
I think the GMPP Intake is nearly as effective as a true CAI because it blocks out most of the underhood heat. The Injen CAI (most that I've seen posted on cobaltSS.net) is inside the engine bay and probably takes in more underhood heat then the GMPP Intake.
the Injen CAI is not in the engine bay at all...
If the filter is inside the fender that's probably the best -- the GMPP intake gets most of it's air from inside the fender too.
