Head Gasket
Old Aug 25, 2010 | 11:51 PM
firefighter404's Avatar
Head Gasket
Is this just a replacement gasket or can i use this for my turbo
http://www.crateenginedepot.com/stor...P2474C200.aspx
Thanks guys
Old Aug 25, 2010 | 11:55 PM
NWAE Cobalt's Avatar
if your using arp head studs buy just a replacement, if you need the bolts anyway (cannot reuse stockers) then buy that kit, itll give you everythign you need at a good price.
you will also need cam sprocket bolts and a crank pulley bolt...all are tq to yeild and will need to be replaced once the head is replaced....
every done the timing or pulled a cyl head on one of these?
Old Aug 25, 2010 | 11:57 PM
im using golden eagle head studs
Old Aug 25, 2010 | 11:59 PM
then just buy a gasket and anything else you need seperate, alot of that price is the head bolts that you wont need
so a stock head gasket will hold boost
Old Aug 26, 2010 | 12:06 AM
in theory, ive heard both ways about cometic too though
i know pleanty of people running boost on a 2.2 without every poppig the head though
Old Aug 26, 2010 | 12:10 AM
its cheaper to buy that metal one so ill use the metal one the stock one is more
Old Aug 26, 2010 | 12:28 AM
wait, wha? the stock one IS metal...
Old Aug 26, 2010 | 01:43 AM
the crate engine depot on is metal
Old Aug 26, 2010 | 01:51 AM
its a stocker :P
Old Sep 1, 2010 | 01:24 AM
so another question is the lsj supercharger intake manifold work for our 2.2 i have a free one and was wondering if i can use it, i heard there is an adapter plate i can use
Old Sep 1, 2010 | 09:58 AM
HyperMuffin's Avatar
Yes, it will work for the 2.2L. You will need a different intake manifold gasket, but I don't think it will work for you. If you are already turbo'ed you probably have a custom fabricated intake mani. If not that is probably the best solution or you will need to buy a block off plate for the lsj intake mani to let you run a turbo application.
Old Sep 1, 2010 | 10:01 AM
originaladrian's Avatar
what are your goals? tons of people boost and spray on 2.2s like mentioned without even touching the head.
Old Sep 1, 2010 | 09:39 PM
well its already order as far as parts for the engine i have pistons rods springs retainers head studs head gasket rod bearings and such. I got this intake mani for free so i figured i could make it work. I can order the adapter plate for the tb. I just want to know what else i need
ineedacobaltss
Nov 7, 2015 02:25 PM
Trav3480
Oct 1, 2015 08:17 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
