Header fitment
Old Oct 16, 2006 | 06:08 PM
That Cobalt LT Guy's Avatar
Header fitment
I was just on the post that just got locked and they said that the han header and the CA header are haveing fittment problems on the 2.2 and Im wondering what header out will fit my 2.2 with out rubing my coolent pipe
Old Oct 16, 2006 | 06:10 PM
NJHK's Avatar
I'd contact Pacesetter. They might have something available for you guys by now.
1SloBowtie's Avatar
Looks like Pacesetter or the GMPP manifold for now...
Old Oct 16, 2006 | 06:15 PM
D4u2s0t's Avatar
pacesetter has one, but it's not a direct fit. You need to do a cut and weld to the downpipe. shouldn't be any fitment issues though. can't speak about any others.
Old Oct 16, 2006 | 06:44 PM
biniecki's Avatar
Wasnt there a problem with mounting the EGR on some of the models. It seemed like some of the cars have it and some don't. If I remember correctly the 05 model arnt effected but the 06 model has this issue. I think TTR was trying to get someone by a header and then send them there stock header so that they could send it to pacesetter to have them make one that would compensate for this issue and in return TTR would give them an upgraded header.
Old Oct 16, 2006 | 06:47 PM
I dont have egr or air injection Im one of the lucky 06 owners
Halfcent's Avatar
I'm old school
Good thread actually. The GMPP header will fit for sure. The Pacesetting header has full length runners, and will require a custom downpipe for installation. That's not as bad as it sounds actually. Any exhaust shop can fab up a pipe for you.
The problem the CA and Hahn manifolds are having is a result of their "shorty" design. They have equal length runners, so they are all smooshed into a small space to fit. I fear I don't have a good solution other then perhaps indenting the one exhaust pipe with the close fit.
As far as the air injection (not EGR) issue, is was only on some late production 2006 models. Not all 2006 car have it. I don't think any of the 2007 models do.
Old Oct 16, 2006 | 06:51 PM
Ill run with the pacesetter I work with a master welder and Ill get him to weld it for me does the pacesetter come with a ball joint to weld on to the down pipe. And since you have done more to the 2.2 cobalt than any body I was wondering if I will throught a cel with this header and a down pipe with a high flow cat.
Old Oct 16, 2006 | 06:53 PM
rally's Avatar
Halfcent I emailed ZZP and they told me their ECOTEC headers should fit our 2.2's. Is that true? They only have the 2.0 listed.
Old Oct 16, 2006 | 06:54 PM
NoRemorse's Avatar
Yes that is true.... this has been more times than I can count, hell more times than check norris can count, and he has counted to infinity... twice
Old Oct 16, 2006 | 07:00 PM
rally's Avatar
so the 2.0 ZZP headers fit our 2.2's for sure. I want a header but fear of pacesetter for quality and fear of CA for fitment
Old Oct 16, 2006 | 07:03 PM
NoRemorse's Avatar
have you ever seen the back side of an LSJ??
It is pretty much identicle to a L61, fitment should be the SAME.
as far as it bolting up to the downpipe.. thts a different story that I am not 100% sure about
skykapp's Avatar
ebay has a few Scdyne headers right now.
Old Oct 16, 2006 | 07:04 PM
wdsoccer's Avatar
Cobalt-addiction is making a new header that will not have any fitment issues on the 2.2l. I emailed Kenny with pics so they can make the header to avoid fitment problems. Give it a couple months and CA will most likely have their new one out.
Im still going to go with the pacesetter I have the pacesetter catback so why not have the header and zzp is more expencive.
Old Oct 16, 2006 | 07:23 PM
rally's Avatar
Yea, CA is redesigning a header they should have tested. Plus i've heard bad things about CA's shipping policies.
Not to mention with all the great technology ZZP has theres no doubt I would go ZZP over CA or Pacesetter
Old Oct 16, 2006 | 07:26 PM
DoubleClutchin_ION2's Avatar
do like me.. get the LSJ manifold...
Old Oct 16, 2006 | 07:27 PM
Witch header are you talking about from zzp the header and down pipe combo or the shorty header
Old Oct 16, 2006 | 07:28 PM
Halfcent's Avatar
I'm old school
Any LSJ header will fit a L61. They have the exact same head geometry.
Old Oct 16, 2006 | 07:29 PM
halfcent will I throw a cel if I put a header and a down pipe on my 2.2.
Old Oct 16, 2006 | 07:42 PM
wdsoccer's Avatar
I had no problems with the shipping from Cobalt-addiction. they shipped on time and they make a really nice header. they also know how to deal with customers.
Old Oct 16, 2006 | 07:50 PM
rally's Avatar
I still trust everything from ZZP over someone like Cobalt Addiction, just me
Old Oct 16, 2006 | 08:58 PM
kjn24's Avatar
did you buy the gm manifold or did you get a manifold off of an ss. cause im in the middle of getting an ss manifold and would like to know your gains. i figure there should be some whether i get it bored or not. as we all know the stock one is terribly restricting.
Old Oct 16, 2006 | 09:20 PM
Halfcent's Avatar
I'm old school
If you are able to retain the use of BOTH of your O2 sensors, you should be fine. Biohazard has this header and has a CEL, but he also removed his cat and isn't using one of his O2 sensors.
Old Oct 16, 2006 | 09:22 PM
06blackg85ss's Avatar
god does anybody pay attention anymore... there were more problems of the ZZP fitment... these are just problems with the 2.2's which for some reason you guys believe needs a header,.... the gmpp manifold or a stock ss/sc manifold would be more than enough... unless you guys are running a procharger or something
