Header fitment
Header fitment
I was just on the post that just got locked and they said that the han header and the CA header are haveing fittment problems on the 2.2 and Im wondering what header out will fit my 2.2 with out rubing my coolent pipe
Wasnt there a problem with mounting the EGR on some of the models. It seemed like some of the cars have it and some don't. If I remember correctly the 05 model arnt effected but the 06 model has this issue. I think TTR was trying to get someone by a header and then send them there stock header so that they could send it to pacesetter to have them make one that would compensate for this issue and in return TTR would give them an upgraded header.
Good thread actually. The GMPP header will fit for sure. The Pacesetting header has full length runners, and will require a custom downpipe for installation. That's not as bad as it sounds actually. Any exhaust shop can fab up a pipe for you.
The problem the CA and Hahn manifolds are having is a result of their "shorty" design. They have equal length runners, so they are all smooshed into a small space to fit. I fear I don't have a good solution other then perhaps indenting the one exhaust pipe with the close fit.
As far as the air injection (not EGR) issue, is was only on some late production 2006 models. Not all 2006 car have it. I don't think any of the 2007 models do.
Ill run with the pacesetter I work with a master welder and Ill get him to weld it for me does the pacesetter come with a ball joint to weld on to the down pipe. And since you have done more to the 2.2 cobalt than any body I was wondering if I will throught a cel with this header and a down pipe with a high flow cat.
Originally Posted by rallyyellow06
Halfcent I emailed ZZP and they told me their ECOTEC headers should fit our 2.2's. Is that true? They only have the 2.0 listed.
so the 2.0 ZZP headers fit our 2.2's for sure. I want a header but fear of pacesetter for quality and fear of CA for fitment
It is pretty much identicle to a L61, fitment should be the SAME.
as far as it bolting up to the downpipe.. thts a different story that I am not 100% sure about
Yea, CA is redesigning a header they should have tested. Plus i've heard bad things about CA's shipping policies.
Not to mention with all the great technology ZZP has theres no doubt I would go ZZP over CA or Pacesetter
Originally Posted by Cobalt_SDN
do like me.. get the LSJ manifold...
Originally Posted by That Cobalt LT Guy
halfcent will I throw a cel if I put a header and a down pipe on my 2.2.
god does anybody pay attention anymore... there were more problems of the ZZP fitment... these are just problems with the 2.2's which for some reason you guys believe needs a header,.... the gmpp manifold or a stock ss/sc manifold would be more than enough... unless you guys are running a procharger or something
