Help picking exhaust components
Old Aug 23, 2012 | 03:28 PM
08baltls's Avatar
Im still running my stock exhaust on my 3.1" supercharger. I want to keep it cost effective and not a total pain in the ass to install. I found a badmab knockoff header for like $120 shipped. I had thought about just keeping my stock catback since it has the resonator delete and a flowmaster. But it's still only 2.25". As far as the downpipe goes I had thought about just using a stock s/c downpipe. But I've got the feeling that at least the downpipe and catback won't actually do much to help.
So I'm looking for better suggestions. So toss them out there.
Old Aug 23, 2012 | 03:59 PM
BLKLS's Avatar
Zzp long tube. Only way to go.
Old Aug 23, 2012 | 04:12 PM
JapEatr's Avatar
South Central *********
buy once, cry once... seriously, buy only quality components... oyu get what you pay for
Old Aug 23, 2012 | 04:40 PM
08baltls's Avatar
I'm not necessarily wanting to go super cheap, I just want cost effective and not a total pain in the ass to install. Preferably a shorty header as it seems a lot easier to fit into place. That's why I was thinking badmab or similar. Then I'm confused on the downpipes. I'm sure something like the ZZP 2.5" would flow better but how much better over the stock s/c?
Old Aug 23, 2012 | 06:26 PM
BLKLS's Avatar
Dude I rocked a cobalt addiction header with a stock lsj downpipe, or a 2.5 catless for years. I would swap between the two every once in a while couldn't decide between the better performance vs the less noise between the two. Then the cat went bad and I had to get inspection so I spent the money on a zzp long tube (and it's less now then when I got it) the differance is like night and day. Just save up and get one. I'm running it threw a stock lsj exhaust feels fantastic.
Old Aug 23, 2012 | 06:30 PM
BlackLsCoupe's Avatar
what ever you do dont get the GMPP header, i had got it off a friend and my base no super chager stock cated and it cracked
Old Aug 24, 2012 | 11:56 AM
08baltls's Avatar
Well honestly, if I go with a long tube style header, I'll probably just go with a pacesetter. It's a he'll of a lot cheaper then what ZZP has. I mean I'm really thinking Badmab is what I'm going with for a header. I found a website yesterday called like mandrelexhaust.com or something that had a 2.5" cat'd downpipe for under $200. I may look into that.
Also, how much of a difference is 1/4" going to make in terms of a catback?
Old Aug 25, 2012 | 04:07 PM
nhanson's Avatar
2.25" will be ok.
I have ZZP midlength combo, and their catback all 2.5"
Old Aug 29, 2012 | 10:09 AM
GoofyBalt's Avatar
08baltls,
I just bought a badmab rep off ebay, tsudo exhaust off ebay and a zzp 2.5 catted dp, bolt it all on did a few adjustments and it sounds good. I had a small leak, barely can hear unless next to something from the header to dp, I sprayed the gaskets with copper spray and now the leak is gone. I would say go for it, i did and it works just fine.
Old Aug 29, 2012 | 03:09 PM
08baltls's Avatar
That's awesome to hear. If you don't mind my asking, what did end up spending in all on that setup? And how were there any noticeable gains?
Old Aug 29, 2012 | 03:16 PM
GoofyBalt's Avatar
$200 for new zzp 2.5 catted dp, $140 on the Tsudo catback, $120 on the rep header. $460 on the header back setup. $8 for the can of Copper spray.
Gains, right now i dont know. I havent really beat on it yet, waiting to the get the s/c on.
Old Aug 29, 2012 | 07:30 PM
08baltls's Avatar
Damn that's a good deal. I'm gonna have to check YouTube and see of I can see any similar sound clips.
Old Aug 30, 2012 | 12:50 AM
scagnetti76's Avatar
I agree. I went the "cheap route" with my header. And am now saving for a quality header and dp set up. I dont want to knock the one i have because they were good to me, it performs well and its only my opinion that my repeated leak from it comes from the manufacturing process/ metal used. Ive replaced three gaskets between it and the head. The leak always returns after about 1000 miles. New GM studs and nuts also. It always leaks from a different cylinder. And yes i know how to use a torque wrench and know the proper tightening order. Just my two cents.
Old Aug 30, 2012 | 08:55 AM
GoofyBalt's Avatar
Did you try using the copper spray on the gasket? It works wonders
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Trav3480
Oct 1, 2015 08:17 PM
