help with using solid lifters in my l61 head
Old May 11, 2015 | 05:01 PM
ezjarecki's Avatar
I have a 2.2 ecotec and im using solid lifter as they aslo came with shims but the shims are too large and if I shave them down there would be really not much left and would just smash bc the specs that cam with them are .0015 to .004 clearance between the rocker and cam which is very small do these clearances sound right? my machine shop says normally the clearances on other heads he has done are larger? and also the only way to get that right is to raise the valve higher in the head which isn't cheap any ideas or ways that anyone has installed this would be appreciated thank
Old May 11, 2015 | 09:24 PM
JapEatr's Avatar
South Central *********
What cams and what lifters?
Old May 12, 2015 | 10:34 AM
ezjarecki's Avatar
Comp x treme energy and ble solid lifters with shims non adjustable
Old May 12, 2015 | 01:04 PM
armcclure's Avatar
The comp lobe profile does not play well with solid lifters. You'll eat the rockets at high rpm.
Stick with stock hydraulics; they act as a cushion.
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
Trav3480
Oct 1, 2015 08:17 PM
footballplaya3k
Sep 30, 2015 09:39 PM
Sep 28, 2015 12:51 PM
