highest safe rev limit.
Old Apr 20, 2009 | 05:23 PM
07blackg5's Avatar
Slobodan Milošević
what is the stock '07 rev limiter?
and what is the highest you can safely rev a 2.2 with the stock valvetrain/internals?
i had my car dyno'd and they stopped it at 6300rpm and the power is still climbing, thats why im wondering. from what i hear the stock limiter is 6800 rpm, but the tach lags so i dont know.
edit: i know the power will level out around the stock rev limiter, but i figure with a tune i might get a little more up top. it might be beneficial to bump the limiter a tad
Old Apr 20, 2009 | 05:39 PM
warrenb213's Avatar
stock internals are rated to 7500 i believe. so i'd say set it to 7100-7200. and be friendly to your engine lol
Old Apr 20, 2009 | 05:43 PM
EXsoccer1921's Avatar
step1. disable all rev limitations
step2. get a 15k LOGGING tach. make sure you can keep track of the rpms
step3. rev till you blow
step4. rebuild and set redline 100rpms below what you blew at.
Old Apr 20, 2009 | 05:46 PM
hugemurph4's Avatar
well anyways did you do this in Mt Pleasant and i think the limit for internals would be 7500 but i would to be safe put it at 7000...you have th 2.4 mani right
07blackg5's Avatar
Slobodan Milošević
i dont know why i didnt think of that
Old Apr 20, 2009 | 09:05 PM
but on a serious note. i have my redline at 7,300 and it takes it just fine
Old Apr 20, 2009 | 09:07 PM
Ruchus's Avatar
7300 ftw you should never hit redline so this should throw your shift to 7000-7100
Old Apr 20, 2009 | 09:08 PM
widowedeight's Avatar
ummmm don't you have a different motor....
Old Apr 20, 2009 | 09:11 PM
Kodatech's Avatar
+1
Old Apr 20, 2009 | 09:26 PM
oh hey, look at that. hahah my bad.
but no i shift at 6500 from 1st-2nd. and then 7250ish from 2nd-third at the track. street i don't get above 3k
Old Apr 20, 2009 | 11:19 PM
NWAE Cobalt's Avatar
with stock valve springs (this is the limiter) it is 7500rpm
anything above that you risk valve float with equals valve tap which equals no runny runny
mine is set to 7000 and no problems
Last edited by NWAE Cobalt; Apr 20, 2009 at 11:19 PM. Reason: Automerged Doublepost
Old Apr 21, 2009 | 12:19 AM
HunterKiller89's Avatar
all non-VVT ecotecs have the same valvetrain. our stck cam profile kind of limits power a bit. you stop building power at 6300rpms. adjustable cam gears or new cams are needed to make use of a higher rpm
footballplaya3k
Sep 28, 2015 11:14 AM
Rduncanss06
Sep 27, 2015 11:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
TylerJHowell
Sep 21, 2015 06:47 PM
