injector problem
Old Oct 23, 2008 | 07:30 PM
heath2004's Avatar
injector problem
i have the cobalt 2.2. what do i need to change my stock injectors to stock ss injetors?
Old Oct 23, 2008 | 07:32 PM
Sw4y1313's Avatar
why do you need the ss injectors? you going turbo? if not then you have no need for them.
Old Oct 23, 2008 | 09:23 PM
heath2004's Avatar
i am turbo need them before tune
does the stock ss injector fit a stock ls injector wire harness
Old Oct 23, 2008 | 09:34 PM
PsychoCam's Avatar
did u get a turbo kit, or do it yourself?
have any pics
injectors will not fit the stock harness uness u re wire it
Old Oct 23, 2008 | 09:45 PM
heath2004's Avatar
do it yourself
Old Oct 24, 2008 | 11:27 AM
tru2nrtt777's Avatar
They physically fit direct replacement but wiring will have to be redone before tuning.
Old Oct 25, 2008 | 02:37 AM
heath2004's Avatar
will the 34lb ss injectors fit in ls model 2.2
Old Oct 25, 2008 | 03:38 AM
Sentry's Avatar
Yes, they're all interchangeable, but to repeat what everyone has been saying, you gotta redo the wiring harness for it to work. Personally, I would go with the 42# injectors from the stage 2 kit.
http://www.zzperformance.com/cobalt_...=481&catid=174
You could also pick up some for cheap by posting a want to buy thread in the classifieds section. But, with 34lbers, you're going to end up needing more fuel than those can supply.
Old Oct 26, 2008 | 05:08 PM
CoolVey's Avatar
The stock ss injectors duty cycle is more then enough for him to around 8-10 psi on his stock internals. Unless he's beefed up his internals and is running alot of boost. He doesn't need more. All you have to do is splice the clips from the ss harness on your 2.2 harness and your set.
Old Oct 26, 2008 | 05:20 PM
Hockeyman's Avatar
you need the cavi harness for them to work, then a tune. Maybe the cavi fuel rail too? The SS injectors are shorter than the stock 2.2's.
Old Oct 26, 2008 | 05:26 PM
CoolVey's Avatar
He doesn't have to have a cavalier harness.
Look at my sig. My stock rail and harness are being utilized with the stock green tops. I just swapped the clips. Trust me, it works.
Old Oct 26, 2008 | 06:17 PM
pacific cobalt's Avatar
There's alot of threads out here about stock SS injectors on a ecotec 2.2
From what I read the fuel injector wiring harness from a 2004 Cavalier with a 2.2 Ecotec will fit if you want to go turbo using stock SS injectors.
Someone correct me if I am wrong
Old Oct 26, 2008 | 08:47 PM
CoolVey's Avatar
Whatever he can get cheapest is probably what he should do. Atleast he has options.
Old Oct 27, 2008 | 05:24 PM
heath2004's Avatar
thanks for all the info . iwill post how it all goes soon
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
