injectors question
injectors question
i have an 07 2.2 and i'm lookin into swappin the injector's for the ss/sc one's i know 05 and 06 are the same and in 07 i know they changed a few things does anyone know if i'd have ne problem's swappin my 07 2.2 injector's with 06 ss/sc injectors?
Yes....the fuel rail will not hold them in the correct place...it's off maybe about a 1/2" inch or so, you will have to get a cavalier fuel rail or eqv. The wiring harness is also wrong, you will have to have a SS/SC harness and hardwire it in the the existing harness....i.e. cutting the plug off the 2.2, and cutting the plug off the ss/sc and soldering the wires from the ss/sc harness to the 2.2 plug to make it work. Also, you will have to keep the MAP wires in place on the 2.2 plug whereas the SS/SC harness does not have the Map wires on the fuel injector harness.
the SS/SC stock injectors WILL NOT WORK in a stock L61 engine without first modifying the fuel rail and harness. If you just try and put them in there, the electrical will not fit and there will be a gap between the fuel rail and the injector port of approx. 1/2". The injectors will physically fit in the fuel rail and the injector port, but not at the same time.
well i have a 2.4 and also have a different fuel rail from the 2.0 but i run ss/sc injectors and the meet the head and rail fine with no problems.. i thoguht the 2.2 has the same fuel rail as the 2.4s which would mean that there will not be a fitment issue
Sl0wbaltSS
Nov 21, 2018 11:11 PM
