injectors question
Old Oct 3, 2008 | 03:28 AM
07candysedan's Avatar
injectors question
i have an 07 2.2 and i'm lookin into swappin the injector's for the ss/sc one's i know 05 and 06 are the same and in 07 i know they changed a few things does anyone know if i'd have ne problem's swappin my 07 2.2 injector's with 06 ss/sc injectors?
Old Oct 3, 2008 | 02:40 PM
FacelessKhaos's Avatar
Yes....the fuel rail will not hold them in the correct place...it's off maybe about a 1/2" inch or so, you will have to get a cavalier fuel rail or eqv. The wiring harness is also wrong, you will have to have a SS/SC harness and hardwire it in the the existing harness....i.e. cutting the plug off the 2.2, and cutting the plug off the ss/sc and soldering the wires from the ss/sc harness to the 2.2 plug to make it work. Also, you will have to keep the MAP wires in place on the 2.2 plug whereas the SS/SC harness does not have the Map wires on the fuel injector harness.
Old Oct 3, 2008 | 03:42 PM
BoffDude's Avatar
thought the 32lb injectors would fit. or is that only on 06?
Old Oct 3, 2008 | 04:12 PM
the SS/SC stock injectors WILL NOT WORK in a stock L61 engine without first modifying the fuel rail and harness. If you just try and put them in there, the electrical will not fit and there will be a gap between the fuel rail and the injector port of approx. 1/2". The injectors will physically fit in the fuel rail and the injector port, but not at the same time.
Old Oct 3, 2008 | 04:20 PM
BoffDude's Avatar
do you know what aftermarket fuel rails will fit the injectors and the L61?
Old Oct 3, 2008 | 04:23 PM
senior_brown's Avatar
the 2.2 has a different fuel rail from the 2.4?
Old Oct 3, 2008 | 04:32 PM
BoffDude's Avatar
i'm talking about the 2.0. the injectors in the 2.0 will not fit on to the 2.2. i guess that means it has different fuel rail.
Old Oct 3, 2008 | 04:36 PM
well i have a 2.4 and also have a different fuel rail from the 2.0 but i run ss/sc injectors and the meet the head and rail fine with no problems.. i thoguht the 2.2 has the same fuel rail as the 2.4s which would mean that there will not be a fitment issue
Old Oct 3, 2008 | 04:49 PM
BoffDude's Avatar
there is no difference in the heads, so it should work. i will have to find out if the fuel rails are the same.
Old Oct 3, 2008 | 04:52 PM
jefferyss's Avatar
I Got 2 Sets Of O.e.m. Injectors If Anyone Is Interested
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
