Installed Stage 2 Comp Cams Yesterday
Old 07-16-2008, 12:00 PM
Rent me! per hour
Area47's Avatar
you do realize that the cam tool from gm holds tension on the chain itself so it doesn't slip at the crank gear right?
your cute little zip tie method. not bright.
Old 07-16-2008, 12:08 PM
elecblue06's Avatar
damnshit sounds evil.. really makes me want cams in my car lol. boost first boost first..
Old 07-16-2008, 12:18 PM
copson20's Avatar
uploading more videos
you know what. when something goes wrong you can say i told you so. the dealer used zip ties on matt car also. im not worried about it.
Old 07-16-2008, 12:24 PM
stenguyen1's Avatar
sweet **** man
just love how it idles n it pops when u downshift to slow down huh?
got to get me some. lol
Old 07-16-2008, 12:26 PM
copson20's Avatar
watch in this order
http://s348.photobucket.com/albums/q...t=100_3545.flv
http://s348.photobucket.com/albums/q...t=100_3546.flv
http://s348.photobucket.com/albums/q...t=100_3547.flv
Old 07-16-2008, 12:30 PM
elecblue06's Avatar
very nice man..
Old 07-16-2008, 12:31 PM
copson20's Avatar
Thanxs
Old 07-16-2008, 12:34 PM
Preston's Avatar
Wow..i wanna do cams and have been wanting to
so how much of a better pull you getting? supporting mods..etc
Old 07-16-2008, 12:47 PM
copson20's Avatar
very hard pull past 3000RPM. you can really the cams kick in. and puts you back into the seat
Old 07-16-2008, 12:55 PM
Preston's Avatar
aww god i want um
Old 07-16-2008, 01:31 PM
  #36
burzumaske20's Avatar
Have you race anyone yet?
Old 07-16-2008, 02:11 PM
  #37
MadBrad's Avatar
I think he need to finish his tune first.
Old 07-16-2008, 02:37 PM
  #38
Spanky's Monkey's Avatar
i'm still holding out for the perfected tune and a dyno. great to see it running and sounding mean but until everythings working right it seems more show then go. thanks for guinea piggin for us and that goes to both you and matt.
Old 07-16-2008, 02:41 PM
  #39
MadBrad's Avatar
Get that perferct tune. Then sit back and realize I still want to go faster.
Old 07-16-2008, 03:18 PM
  #40
I am sure with the stage 2 cams when he needs to adjust some things with the tuning, that his car will be running a hell of a lot quicker
Last edited by burzumaske20; 07-16-2008 at 03:19 PM. Reason: Automerged Doublepost
Old 07-16-2008, 03:20 PM
  #41
Psykostevo's Avatar
Zip ties!
Schweet!
Old 07-16-2008, 03:39 PM
  #42
i don't doubt it'll be faster i just want to see by how much and where this newfound power lies. i'd rather not end up trying to wind out the engine like its a vtec, if you know what i mean.
Old 07-16-2008, 03:45 PM
  #43
well doing internal work on a motor will have some gains but no one has dyno the stage 2 cams yet with other bolt ons.More dyno tests less explaining on what you feel in the car
Old 07-16-2008, 03:46 PM
  #44
BlackBalt's Avatar
So did you also have to upgrade your valvetrain? I would think the more agressive ramp and higher lift of this cam would cause problems with valve float.
Old 07-16-2008, 03:52 PM
  #45
massivematt's Avatar
Thumbs up
Everything is working right. Also every car is going to act a little different; so you will never have a so called perfected tune. You have to adjust to what your ECU likes. Cams are an excellent way to make more power. The more air you can suck in and let out, the better. Trust me it has plenty of "go" to it. As far as "guinea piggin", It's not like we were experimenting to see if they would work. I knew for a long time I could put different cams in.
Old 07-16-2008, 03:55 PM
  #46
this is being debated now but they haven't gotten the revs that high yet due to the current tuning process. i believe whole-heartedly that these cams are going to build better power beyond the points that the stock springs are designed to manitain power at which point they will bind causing the valves to float.
without upping the springs and retainers i'd call you a guinea pig my friend. whats up with some high revving load bearing vids?
Last edited by Spanky's Monkey; 07-16-2008 at 03:55 PM. Reason: Automerged Doublepost
Old 07-16-2008, 04:00 PM
  #47
black06ss's Avatar
cant see pics due to firewall stupid firewall.
Old 07-16-2008, 04:01 PM
  #48
Talking
You can accomplish the same thing by unscrewing the cam chain tensioner bolt from the back of the block. Why argue about this when it has been successful for 2 cobalts so far?
Old 07-16-2008, 04:12 PM
  #49
o3nisoaso3's Avatar
i did the same of my friends 2.2 last nite too! lol
Old 07-16-2008, 04:17 PM
  #50
Talking
So far the highest i have shifted at is 6000. I have the shift points set at 6475. Yes i am a little weary about bringing it to 6400 so i havent yet. So your still getting almost all the power out of them. I will probably never have to bring it that high anyhow because whoever im racing, i've already smoked em' within the first 50 feet.
Quick Reply: Installed Stage 2 Comp Cams Yesterday
